rawjunk
by rawjunk on Sun May 19, 2024 10:52 am
warickwrx wrote: ↑Sun May 19, 2024 6:14 am
rawjunk wrote: ↑Tue May 14, 2024 6:22 pm
Do anyone else had problems with their rear derailleur hanger? There is a noticeable gap between the hanger and the frame when the wheel isn't in place. I used cheap tool to align the original hanger but there was still chain rub on 12th gear. I ordered new one and it's definitely not straight either.
I have 10-50 XD cassette + 1,85mm spacer on a DT350 XDR freehub body.
I experienced a similar problem. There is a reaonable gap when the wheel is removed, however the axle obviously takes this up when hub is installed.
Perhaps it is to accomodate the flip chip design. I am running flip chip in the shorter mode. I found that upon initial instalation of groupset one or two gears seemed to be out when setting limits. I replaced the hanger thinking that the origionl may have been bent during transport. The problem was still their. However after some riding the gear's seem tohave settled now and shifting is 100%.
I guess so. I need to try the short position, now the bike rides like a train.
I think I managed to damage my freehub body slightly so the cassette wasn't deep enough. Now the chain isn't rubbing on the hanger anymore but there is a issue with one cog when shifting to easier gear (11th > 10th gear, I think).
mistap
RDY
samarskyrider
by samarskyrider on Mon Sep 09, 2024 4:19 pm
Just bumping up a thread
This weekend finally got my hands to installing SRAM Force XPLR RD with 10-44 cassette and 46T. Was pleased with gear spacing on XPLR cassette
stoney
rider86
by rider86 on Tue Sep 24, 2024 11:29 am
samarskyrider wrote: ↑Tue Sep 17, 2024 4:09 pm
Finally, new tires arrived - Schwalbe Thunder Burt 29x2.1" The look is now complete
How much clearance is there left in the back? I have some unused old Thunder Burts in 2.1" from 2014 laying around...they are only 360grams
samarskyrider
by samarskyrider on Tue Sep 24, 2024 11:54 am
rider86 wrote:samarskyrider wrote: ↑Tue Sep 17, 2024 4:09 pm
More than enough. By the way, theyve beefed up since then. Actual weight is 560gr
rider86
by rider86 on Wed Sep 25, 2024 9:23 am
One of my thunder burts is even 2,25" /57mm. But it still fits in the back with 0,5cm clearance to chainstays and 1cm to the rest of the frame. Should be fine.
