OPEN U.P.P.E.R. - 6.76kg
Just finished my first true gravel build after selling my CX bike last year and missing the fun had on it.
Spec is pretty much maxed out, DA R9170 Di2 / XTR, MCFK everything, Quarq, Berk saddle, Rene Herse 44c tyres.
Looking forward to getting out on it and seeing how shes goes... Trip to Wales booked in 4 weeks time
IG: RhinosWorkshop
IG: RhinosWorkshop
Custom built MCFK 35mm gravel wheels on DT180EXP hubs.
IG: RhinosWorkshop
IG: RhinosWorkshop
11-40T XTR cassette with a WolfTooth 44T chainring.
IG: RhinosWorkshop
IG: RhinosWorkshop
I have a few pairs to choose from, as well as some 40c Challenge Strada Biancas and 42c Ultradynamico Cava Races'
IG: RhinosWorkshop
IG: RhinosWorkshop
I like this but the gum walls why oh why.
I like the gum walls, especially with a predominantly black bike.
@ryanw you will have to let me know how you get on with the Steilacoom's, I've been tempted by them as a wet weather gravel tyre
I saw on Instagram you had some ultra dynamicos..ryanw wrote:I have a few pairs to choose from, as well as some 40c Challenge Strada Biancas and 42c Ultradynamico Cava Races'
Once I have to replace the turbo cottons I’ll try RH EL in 26c
my gravel bike was that light......................................once
2024 BMC TeamMachine R Building
2018 BMC TImeMachine Road
2002 Moots Compact-SL- getting aero look makeover
2023 Pivot E-Vault - completed project, full Xplr package
Nice Build and tire stash! I have an Open Up that I just installed the Barlow Pass EL's on and I really like them. I would like to try the Snoqualmie Pass and Hurricane Ridge tires but the spec on the Open frame says 40mm max @ 700c so I did not want to buy them without knowing they would fit first. Do the Snoqualmie Pass tires work fine with enough clearance? Have you tried the Hurricane Ridge?
Awesome bike! I am currently building an open up in gray (like the one on your wall, but they seemed to have changed the color scheme around the lower headset to just orange instead of multi-color - oddly surprised when I got it).
The shop had a demo bike that I put my Enve G23s with Rene Herse Hurricane Ridge 42s in the back to test clearance. The wheel spun, but there was very little clearance between the tire and the seat tube. I did not get a chance to measure, but it did not look safe. I think that Open calls for at least 6 mm between the tire and frame. How is the clearance with the RH Snoqualmie Pass tires? It looks pretty tight! They appear to be the Extralight version. Did you have any trouble getting them to set up tubeless? I hear that the extralight version weeps sealant. I have standard and endurance casing. They have been great; especially the endurnce casing. I will probably run the RH Barlow Pass on my Open. I still need to decide on a wheelset for this bike.
Last question - what bottom bracket are you running? I am building the bike with 2x GRX, so I ran a Wheels Manufacturing 386EVO Angular Contact BB for 24mm (Shimano) Cranks - Black. I also switched out the Cane Creek headset for a Chris King.
Thanks!
Thanks!
