Juin Tech/Yokozuna bleed? Mine are locking up under heat
There is the Juin Tech R1/F1 bleed thread that asks the same question but no ansewrs and only a link to Juin Tech's Facebook page. Since it is a closed system and given the relatively low costs, my guess is that replacement is easier than bleeding. Finally, there is a thread on singletrackworld.com in which the question is asked about a Juin Tech calipers in which someone does offer a brief desciption of how to bleed the caliper in question.
- Michael
- wheelsONfire
Don't they have a service request email or pdf or even video clip of this procedure?
Bikes:
Open *UP* (2016.04.14)
I have opened them to squeeze out a little oil so that the pads would be wider appart, but have not done a full bleed. Letting out a little oil was very straightforward.
My own research has not turned up any service documents from the company. The most information came from the re-branded Yokozuna company, but they say they shouldn't need to be bled. Wondering if you can contact them to see if they have any experience.
https://www.yokozunausa.com/downloads-instructions-yoko
Anyone have any luck on this or adding oil? Like an idiot, I tried letting a little oil out to give me more clearance, and I think I let too much out and will have to add some oil.
So, following up my post above -- where I let out too much oil and possibly let in some air -- I did add oil and bleed my Juin Tech GT brakes the other day.
I followed the process in the video for the TRP Hy/Rd calipers I found on YouTube, using two syringes and removing the caliper from the forks for ease of use and the pads from the caliper to avoid contamination. I used Finish Line mineral oil, which, coincidentally, is the same greenish color as the oil that came stock in the Juin Tech calipers. The ports are pretty much the same as the M5 port used in 1/2 of the Shimano bleed kit. The one problem I had is that both bleed ports on the Juin Tech GT calipers apparently are shallower than the standard Shimano port and so the fitting bottomed out before contacting the o-ring seal. I just tightened by hand as much as possible and had some, but fairly minimal, leaking, even when compressing the piston (with a brake block/spacer in place, of course!) to make sure all air bubbles were worked out.
In the end, my refill and bleed seems to have been successful. The piston is much firmer again, like how it was delivered. There does not seem to be any leakage at the bleed ports, though I will keep an eye on them. Clearance is still very tight, though, with new stock pads and Shimano XT discs (which is the issue that led me to crack them open in the first place to let out a "bit" of oil). Of course, ymmv, and anyone undertaking this procedure does so at their own risk and apparently voids the warranty as well.
Has anyone had an issue w the Yokozunas where the first pull on the brakes after awhile doesn't produce enough clamping force at the disc? That is, similar to a full hydraulic system that's in need of a bleed?
I'd not have thought caliper-only hydraulic systems would behave like that, but I've noticed this a few times seemingly at random with the Yokozunas. First squeeze after sitting a bit isn't super powerful, but then they get better.
Just adding another experience to the thread: I have Juin Tech GT-4 for a tandem bike, and I had the problem that many seem to have with overly tight spacing, even with the adjustment screw maxed out. I opened one bleed port and just from overpressure a drop came out, so I tightened it up again immediately without letting out more. That very small amount of oil getting out seemed to have done it, I got a bit more space. I totally get it that it must be quite big risk to let out too much and having to bleed them.
I'd also say that clearance is still a bit on the tighter side, it requires a nearly perfectly straight disc rotor, but I cannot open it up more as due to the very long cable run for the rear brake on the tandem, to get full brake power I need to pull the braking lever almost to the bar as it is.
Other than this quirk with the tight spacing I've been satisfied with the brake. Yokozuna reaction brake cables and housing combined with these make the braking good enough. Since I have a 3x10 with corresponding tandem chainset upgrading the whole system to hydraulic would be costly.
