Long axle MTB pedals
I recently bought a pair of ultegra long axle pedals for my road setup and I loved them instantly. They fixed a lot of discomforts on the bike I'd been struggling with to fix in any other way.
Now I am looking to find something similar to replace my MTB pedals but am struggling.
It's for a CX bike if that matters, would prefer shimano but open to suggestions obviously.
Crank Bros do/did LS versions of their pedals.
I assume you've already pushed the cleat as far left/right as it will go?
Something like this might help: https://www.bikefit.com/c-13-pedal-spac ... nders.aspx
I too use longer spindle pedals, but I'm talking serious extra length. None of this 4mm nonsense. My feet are not parallel with each other. If I stand with my knees facing straight ahead in my natural stance, my feet are splaying outwards. That is, there is more distance between my toes than my heels. Have a look at your cranks and chain stays. Do they have rub marks? If I don't allow my feet to rotate the way that they naturally do, I will give myself serious knee issues and probably other detrimental alignment issues. So I need distance between my heel and the crank arm, so that I can turn the cleat a bit and still have clearance between my heel and the crank arm while comfortably pedalling. Just having a wider Q factor isn't the same thing. The only two options I have found are SQ Lab and Issi. Both are Shimano SPD compatible and have something like +12mm spindle lengths. Issi are a great pedal in general as they have all 3 sealed cartridge bearings and no bushings. Spin really well. I tried using pedal spacers initially that thread onto the end of your spindle to give it extra length but I broke these immediately and didn't have confidence in them. These complete pedals have been really reliable and as a bonus gives me some extra stance width which gives me more stability on off-road terrain.
So I went and measured the spindle and indeed they are the same length as the long axle ultegras. Even though I was sure my cleats were correctly setup I doubled checked them. Of course they were set all the way in the wrong direction...
So thank you for your suggestions but the problem turned out to be incompetent home wrenching. Maybe someone with the same issue will find this on google and spare themselves the embarassment!
Yes: long axle SPD-SL is the same as normal axle SPD.
There is a short axle XTR SPD which is the same as SPD-SL.
