What derailleur size i need
Hi, i have a cannondale superx with 1x Sram rival 11s (11-32) speed group set
I want some extra spinning during steep climbs
The front gear is 40T and i want to fit a 11-36 cassette, what size resr derailleur do i need?
I have a Sram rival with clutch(short cage i think?) and its maxed out
What derailleur size i need? i want to stay with sram and with clutch preferable
A Wolftooth Roadlink will do the job and will be cheaper than buying a new rear mech:
https://www.wolftoothcomponents.com/products/roadlink
Wow even better!CampagYOLO wrote:A Wolftooth Roadlink will do the job and will be cheaper than buying a new rear mech:
This exact model will fit?
YepMcdeez wrote: ↑Wed Jun 09, 2021 4:49 pmWow even better!CampagYOLO wrote:A Wolftooth Roadlink will do the job and will be cheaper than buying a new rear mech:
A 36 will fit, you just need a longer chain.
If it's a long cage, you can ride up to a 46t cassette.
Thanks!CampagYOLO wrote:YepMcdeez wrote: ↑Wed Jun 09, 2021 4:49 pmWow even better!CampagYOLO wrote:A Wolftooth Roadlink will do the job and will be cheaper than buying a new rear mech:
As above, you don't need it. You just need a longer chain. The medium cage Rival 1x mech you have is officially rated to take an 11-36.Mcdeez wrote: ↑Thu Jun 10, 2021 12:25 pmThanks!CampagYOLO wrote:YepMcdeez wrote: ↑Wed Jun 09, 2021 4:49 pmWow even better!CampagYOLO wrote:A Wolftooth Roadlink will do the job and will be cheaper than buying a new rear mech:
Take a look at Garbaruk too. Basically swapping out the cage.
