Minimum width clincher rim for 35-38 mm gravel tires
LouisN
by LouisN
Looking for some clincher rims for my wife's gravel bike.
I'll use 35 mm tires for now, and eventuallt try 38 mm if the frameset clears them.
Questions is: What's the minimum width acceptable for rims, to have a decent fit ?
I could use some Mavic Aksium if ever...
Thanks guys, happy riding :beerchug:
Louis :)
emotive
by emotive
Anything from 15mm to 25mm inner width will be fine. 20mm and up will corner on tarmac with less roll.
NickJHP
by NickJHP
My touring bike has been using 37/38mm tyres on Mavic MA2 (13mm internal width) rims for many years. Less than the nominal ideal rim width, but the handling with that combination is fine - I've crossed both the Alps and Pyrenees with that setup.
pdlpsher1
by pdlpsher1
By 'clincher' I take it you meant rim-brake rims. Rim-brake rims are typically narrower than disk rims. They will be fine, but you should find the widest (internal width) rim possible for a decent fit. I have some 40mm gravel tires on 25mm and 20mm (internal width) rims. The 25mm is definitely the best fit but the 20mm rim works too despite looking very ugly (tire is shaped like a light bulb).
Hexsense
by Hexsense
19mm internal width is the minimum I'd go for for gravel wheelset.
I already feel the difference between in tire stablity at low pressure with 19mm and 26mm internal width with 38mm tires. So, I wouldn't like anything narrower than that.
USAisDOA
by USAisDOA
NickJHP wrote:
Sun May 23, 2021 1:11 am
Ah.. a voice of experience. :thumbup:
I believe almost nothing I read and 'hear'
I believe roughly half of what I see with my own eyes.. in person.
I do not carbon.. anything
:nospamhere:
MikeD
by MikeD
Check the ETRTO rim table.
