Well, a collarbone injury on December 31st took me away from biking for 3 months, but I'm finally back at it and had a chance to take some pictures of the finished assembly.
12.7lbs as pictured, you might say that's not enought gear range to call it Gravel, but It clears all my routes that I typically do. it's a 9-32 3T cassette with 38T Ring up front.
Magura latest Mt8 levers, combined with Brake Force One H20 hose (the lightest ever, also alloying me to use heat to create that curvature next to the lever), and X-Tube Heat Shrink Wrap (put on ebay) creating a very nice finish with the handlebar.
Security titanium bolt M4 replacing the compression starnut assembly
Internal view
First, I repositioned the Derailleur Hanger, with a forward bolting placement, SRAM Red short cage RD with a small bridge to offset the top pulley similar to 'Type 2.0'. I also turned the spring inside the RD to increase the chain tension
Since it's electronic, I don't need the barrel adjuster
X-shifter placed on the bottom of the frame (I know, not an ideal position with mud, but I'm deciding to give it a try, worst case I'll move it to the side of the frame next to the crank)
Elsa and Anna band-Aid to hold the hose in place (I have two daugthers)
Reliable seatpost clamp with M6 Titanium Bolt and Hex Nut (upgrade from original)
SRAM Force Brake Calipers with Upgraded hollow Titanium bolt (I wanted Red to match with the RD, but they have both the same weight...eventually I'll find a set of Red's)
Cyclocross Rear tire giving me lots of traction for those steep gravelly hills
