What lube for filthy gravel rides?
Hi All
Curious what lube everyone uses for wet and mucky gravel rides? I've been using Smoove for a while now, but during todays filthy ride my chain sounded like a bag of spanners for the last 40km! I'm thinking maybe I need to go back to using Morgan Blue Race or Syn lube...
Thanks in advance!
Thanks in advance!
Canyon Ultimate CF SL
Canyon Grizl CF SLX
Open U.P.
Canyon Grizl CF SLX
Open U.P.
People often say water washes off hot-bath wax on chains. Personally I have not find that to be the case. IMHO wax is probably the best lube for extreme conditions. I ride in the winter when we have melted slush and road salt on the paved roads. The hot-bath wax has held up as good as when the conditions are dry. Hot-bath wax is all that I use for road and gravel riding.
- HotWireMyHeart
That combination of dirt/grit and being washed by spray constantly (in the UK, at least) is going to get most lubes off, however good they are. I use Muc-Off wet lube and just accept that I need to liberally apply it and then clean and re-apply it after each ride.
This is what I've typically done. Muc off wet, followed by a wash and reapply after each ride. However, I recently set my gravel bike up on Absolute Black Graphenwax. I've yet to take it out on a wet and filthy ride, but I'm quite curious to see how it holds up.HotWireMyHeart wrote: ↑Mon Feb 08, 2021 10:03 amThat combination of dirt/grit and being washed by spray constantly (in the UK, at least) is going to get most lubes off, however good they are. I use Muc-Off wet lube and just accept that I need to liberally apply it and then clean and re-apply it after each ride.
Wilier Cento10AIR - SRAM Force AXS - Road/race
3T Exploro - SRAM Rival AXS XPLR - Gravel
Wilier Sestiere - Shimano Tiagra - Commuter
YouTube link: https://www.youtube.com/@JMCyclingVideos
I'm going to try the extra dry version next as it has some very good reviews.
I tried NFS, after applying it as per the Zero Friction Cycling guide my chain was the loudest it's ever been!
Canyon Grizl CF SLX
Open U.P.
Canyon Grizl CF SLX
Open U.P.
I don't know why Smoove isn't working for you. It works the longest of any lubes I've used for dusty conditions. I also thought it works well in wet conditions too, but I don't ride in mud and wet conditions. Run a heat gun over your chain after application as it Smoove has trouble penetrating the chain because it's relatively viscous.
We use Squirt here in Portland.
No mess and no fuss.
Eco and the fastest lube out there.
Portland based
Sagan SS 2012 Team Issue
Squirt lube here in Sweden. Still fascinating that it works so well and the chain looks somewhat clean even after some absolute nightmare conditions (below freezing point, mud, you-name-it). I run it on all my bikes now during all conditions. Sounds like an ad, i know, but it really works great. Used to use Muc-off before that.
2023 Wilier Rave SLR
2022 Wilier Filante SLR
2021 Cannondale Scalpel Carbon 2
Ceramicspeed UFO drip is the one for gravel for me. I can't afford to hot wax gravel bike after each ride so I prefer drip lube for it.
Unlike Silca drip on or Smoove or other wax,
New formula Ceramicspeed UFO drip has the disadvantage that it doesn't stick very tight to the chain and just fall off in not so long time.
However, unlike other wax, the UFO drip doesn't leave black gum behind on the chain.
So, after one gravel ride that completely cover chain in dust, dirt, grime. I clean the bike with just water and some rub (no degrease). Then apply UFO drip on it. Repeatedly, other wax would cumulate black gunk around parts of the chain and pulley wheel. But Ceramicspeed UFO drip doesn't.
For you guys running wax or squirt etc in the wet, how the hell do you stop your chain rusting? It doesn't seems to matter what I try, or how well I clean, dry and reapply, the rust always appears. Really trying to avoid going back to wet lubes because I love wax in literally every other condition!
