Even if you get it to work it wouldnt be ideal. I guess a smaller roller can rest in a bigger groove but a bigger roller and a smaller groove dont play well with each other.
Clear the confusion with Sram AXS Flat Top Chain Compatibility.
Thanks @aquilinx and @jfranci3. That's what I thought too.
If I am correct at the moment SRAM does not have any 12sp chain ring that could be used with a Quarq PM (110 BCD) and would be suitable for gravel.
Edit: the SRAM 12 sp chain rings are only compatible with their newer PM (107 BCD).
Thanks Matte, that's a shame. I did see in this thread someone using the Eagle chain so might have a look at them.
Could you post a link to the thread please. I can't find it.
Cheers
Ok so I have a kmc 12, an sram red and xx1 chain on order to check this all out for myself.
I'll figure out what works with what and post the results next week.
My bad the thread title was different, but appropriate topic viewtopic.php?t=163976Steve Curtis wrote:Could you post a link to the thread please. I can't find it.
Cheers
Even this one has interesting info viewtopic.php?t=163564
Inviato dal mio iPhone utilizzando Tapatalk
Be careful with the KMC.. please share your results maybe with a Sram red crankset it works better / you could make it workSteve Curtis wrote:Ok so I have a kmc 12, an sram red and xx1 chain on order to check this all out for myself.
I'll be using a stone chainring x1 so hopefully I won't have any issues.Matte86 wrote: ↑Sat Aug 14, 2021 2:47 pmBe careful with the KMC.. please share your results maybe with a Sram red crankset it works better / you could make it workSteve Curtis wrote:Ok so I have a kmc 12, an sram red and xx1 chain on order to check this all out for myself.
I picked up the xx1 and red chain just because I found someone who had them for sale.
They'll all get used eventually but I think I'll just do some testing to see what shifts best. Which is least noisy etc.
Thanks for the link, I'll check it out.
Good evening, please allow me a question: I recently changed my front SRAM Red AXS 12 speed chainrings from 50/37T to 54/41T (in my TT bike). So I know need to
accordingly enlongate my chain. How am I supposed to do this? I do have a portion of the initial chain, but I do not have a connection pin (like the Shimano one).
May I use one more quick link? Thank you in advance, George.
2023 Cervelo S5, size 56, sapphire/ice
- Moderator
I'm running force AXS RD with SLF aero OSPW, Campy 12 speed cassette, Eagle chain and aerocoach oval chainring on my TT bike. Works surprisingly well and I don't have a 10 tooth but do have really nice jumps between gears (11-32)
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
