1X VS 2X which is better
Thejingerr
by Thejingerr
1x 36t with 10-36 (10,11,12,13,15,17,19,21,24,28,32,36)
Pros: 1x, easy climbing and enough speed for flat
Cons : Big Gapes :?: low speed when descending :?: ±1% watt penalty vs 2x
OR
2x 46-33t with 10-33 (10,11,12,13,14,15,17,19,21,24,28,33)
Pros : Small gapes and high speed when descending
Cons : Additional details
  • 1x (36T with 10-36) good enough for 12sp bikepacking?
spdntrxi
by spdntrxi
because I'm not racing for a podium and tend not to be cadence sensitive 1x is fine for me.
1:1 ratio ok for backpacking?.. depends on steepness of terrain and how much you plan to carry. For me it would not be enough of a low gear.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
kode54
by kode54
Depends on gravel and chunky stuff as well as the pitch of terrain.
I don't have too much steep gravel hills around me but when I do, I wish I had more than a 40T and 9/36.
80 pavement, 20 gravel for me.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
Thejingerr
by Thejingerr
What about Gapes ? Is it matter if cassete 9-36 or 9-40 ?
robertbb
by robertbb
It's all about maximising the gape.
Sorry, wrong forum.
spdntrxi
by spdntrxi
robertbb wrote:
Sat Jul 04, 2020 12:45 am
Sorry, wrong forum.
you aussies always going big
2023 Pivot E-Vault
Zdlux
by Zdlux
For me, 1x is my weapon of choice. It's more more simple and I don't feel like I'm missing out with a single in front.
Currently running 40t with 11x42 and will probably switch to a 10x46 cassette soon. I don't care about top speed and tend to do a lot of steep climbing.
I would definitely run something easier than 1:1 for bikepacking but like someone else said, it depends on your terrain.
robertbb
by robertbb
spdntrxi wrote:
Sat Jul 04, 2020 12:48 am
Sorry, wrong forum.
Yep. Stick it in the big ring and just grind :mrgreen: :thumbup:
Js2
by Js2
I prefer 2x, similar range minus the cadence gaps. For pure off-road I find 1x to be good enough, but I do miss it big time on road rides (solo/group). I guess I'm still a roadie at heart haha
gwerziou
by gwerziou
1x is wonderfully simple and linear, especially great for shorter rides, but the gaps are tiring and for longer rides 2x gives you enormous range and versatility without having to run a dinner-plate cassette. I'm now switching to 2x from using 1x for several years. I was initially intending to switch to 2x shortly after getting the bike the 1x came with, but ended up enjoying it so much that it took me more than 3 years to make the switch.
• A hi-zoot bike, pretty sweet
• An old bike, more fun than the new one actually
• Unicycle, no brand name visible
fourfa
by fourfa
1:1 bottom gear nowhere near low enough for bikepacking, unless you like walking or are touring flat farm roads. Not enough information provided to answer the question.
If I was actually using my gravel bike as a mountain bike (driving to trails, hammering challenging terrain, needing 2.1"+ rubber) I'd definitely opt for 1x and dropper on left shifter. Instead I ride long paved miles from my house to shortish trails, I tour and bikepack, and I switch to road wheels and do lots of pure road days, all on the same bike. So 2X is much more versatile for me, hands down. I added a dropper lever inside the left drop and it's good enough.
ultimobici
by ultimobici
Prefer 2x. 44/30 x 10-36 with XTR. Works a treat.
Steve Curtis
Location: Hampshire UK, Dublin Ireland and Geneva Switzerland.
by Steve Curtis
To the op.
Only you can decide. Only you can tell if you can manage gaps between ratios and the terrain/ weight you'll be carrying.
If you're unsure you should probably stick with what you know.
I went x1 before it was a thing. Probably seven years ago on my road bikes. In that time I've lived in London, Dublin and Geneva so a huge mix of terrain. No problem, just swap cassette out chainring to suit. Or just have a double that works most places.
fourfa
by fourfa
ultimobici wrote:
Sat Jul 04, 2020 8:44 pm
What 10-36 cassette? 2x12 with sram XG-1270?
ultimobici
by ultimobici
11 speed S-Road from aliexpress.
