Factor LS
Tifosiphil
by Tifosiphil
Looks like the Garbaruk version
young
by young
Tifosiphil wrote:
Thu Jan 21, 2021 11:49 am
yup. and eagle chain.
young
by young
here's mineImage
7kg with eggbeaters and quarq pm
gwerziou
by gwerziou
Very nice. Looks like you're using your own headset spacers with their stem, is that what I'm seeing?
• A hi-zoot bike, pretty sweet
• An old bike, more fun than the new one actually
• Unicycle, no brand name visible
teutoned
by teutoned
Please,
Can I get some FULL FRONTAL shots that show your cable routing?
This is my 3rd bike build.
My first hydro disc w/ cable shift.
Seems I never can get the routing/length on the first try and end up redoing it.
Also, I would appreciate any tips on figuring proper housing/hose length from handlebar to headtube entry point
Thanks
kode54
by kode54
The LS only comes with round spacers. Its a shame because those special spacers are plastic molds and can't cost much. I had to order some from Factor.
gwerziou wrote:
Thu Jan 28, 2021 8:47 pm
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
christonge
by christonge
fbonde wrote:
Tue Jan 19, 2021 7:00 am
Done with the LS build.
Size 54"
Enve finishing kit (with the new AR handlebar)
Enve 3.4 AR's
almost 8 kilo
The only downside was the cable management with no stop like the OPEN. It slides back and forth in and out of the frame. Not the best solution. Otherwise a fantastic bike, gravel yet still a racy feeling.
Quick question for Di2 users... have any of you used the E-Tube unit in the downtube? and if you could post some front-end pictures of cable routing it would be much appreciated. Thanks, Chris
gwerziou
by gwerziou
The cable that's sliding back and forth - this is a derailleur cable, or the rear brake cable?
kode54
by kode54
Looks like shrink tubing on hydro hose and Di2 eTube wire.
- Factor LS Disc
gwerziou
by gwerziou
Oh OK. I'd prefer a rubber grommet or such, but if it's just a hydro hose that's not a big deal for me.
kode54
by kode54
gwerziou wrote:
Thu Feb 11, 2021 11:34 pm
Best to use a dry lube so as not to bind when turning.
- Factor LS Disc
req110
by req110
I have my Trek Boone 7 AXS my2020, where from i will sell the frameset and keep rest of components, and going to build:
factor LS black 54cm
bontrager paradigm elite carbon 108T internal 25mm, 25mm high
sram force AXS
crankset Force AXS D1 40T 172.5mm on GXP BB (yeah i know DUB would be better, but i have GXP crankset from Trek Boone)
BB Token BB Right > GXP
Farsports F1 100x420 cockpit
MCFK seatpost
I should have it finished by next friday.
As tires, i have chosen the Panaracer Gravel King SS (semi slick) 38C for my purposes.
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
req110
by req110
Just finished this
scoobydrew
by scoobydrew
young wrote:
Sun Jan 24, 2021 3:11 am
here's mine[img]https://i.imgur.com/EzrcUfU.jpg[/img
Looks great! What size is this?
cerro
by cerro
req110 wrote:
Sat Apr 10, 2021 3:03 pm
Just finished this
Nice, my Factor LS with Force 1x12 is awesome. :D But that saddle angle doesn't look comfortable at all
