Factor LS
kode54
by kode54
Factor was transitioning about then maybe? My friends LS has SLT with T47A BB as well.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
Erwin
by Erwin
My LS has T47A, but standard bearings, no CS and no CS SLR.
Here is picture from my steerer caps, left to right: Ostro, O2 VAM, LS
The LS cap is only black, O2 has CS headset and Ostro CS SLT
bmCube
by bmCube
When I replaced mine, I saw they were the same I ordered. So, enduro black oxide. Hope these will last a little longer....
vanitypl
by vanitypl
Has anyone had any issues with the derailleur hanger shifting down and stopping the thru axle from threading properly into the frame?
I followed the manufacturer recommendations (loctite + 1Nm torque) for hanger installation, but have found that the added weight of the derailleur is pulling the hanger down despite this.
I'm still able to get the axle through with a bit of jostling, but it takes 10x longer than any of my other bikes and was hoping there was an easy fix that would make wheelset swapping (something I intend to do a fair bit) easier.
vanitypl
by vanitypl
duplicate post, deleted
kode54
by kode54
Loosen bolt on hanger. Put thru axle on without wheel. Jiggle the thruaxle as to center it and find a smooth insertion path. Tighten bolt on hanger so it stays in place.
Then reassemble with wheel and thru axle with grease. Should be better then.
- Factor LS Disc
bmCube
by bmCube
:smartass: as said above!
