New Exploro RaceMax
Dubadai
by Dubadai
It depends probably a lot on how you ride... I do a lot of zone 2 riding, and its really hard to keep power down when its 8% climbs and cadance drops... So i only ever use it on the very steepest parts!
uquality wrote:
Wed Apr 14, 2021 4:26 pm
emotive wrote:
Sat Apr 10, 2021 10:26 am
I’m running 48/31 GRX cranks with 11-34 on the gravel wheelset and 11-30 on the all-road wheelset. It’s good to have the 1:1 gearing for steep gravel.
I don’t adjust the set screw when I swap wheel sets.
Awesome. I always think the 34 is too big for even gravel, but maybe not.
S-Works Venge 2020
S-works Aethos
Specialized Diverge 2021
eajohnson
by eajohnson
(deleted)
JackieJunior
by JackieJunior
Sharing my frameset with a litle DIY spraycan-work.... Will add some more pics once the building process is back on track: this was just phase 1... Apologies for bad pics. (I am afraid it added some weight to the RTP frameset...)
kode54
by kode54
That's a really nice rattle can DIY job. Excellent! Like the color and minimal graphics.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
JackieJunior
by JackieJunior
Short update - currently in the middle of taking off my AXS group from my other bike to mount on this baby. Delivery times for SRAM are outrageous.... :-( And the ENVE aero bar is also still on its way...
basurper
by basurper
Guys, what cadence sensor do you use on your RaceMax? Given the very tight space between the non crank arm to the chainstay.
Sent from my SM-N960F using Tapatalk
Josku
by Josku
basurper wrote:Guys, what cadence sensor do you use on your RaceMax? Given the very tight space between the non crank arm to the chainstay.
Sram cranks and integrated Sram quarq power meter
uquality
by uquality
First ride on my Racemax today.
I am 173cm tall, size 54 frame. 40cm bars.
Went with 110mm stem and am wondering if that's a bit long? OEM stem is 90mm.
Also, even with a long stem the bike felt twitchy with 32c tires.
basurper
by basurper
Thanks for the info.
I finally choose the old garmin gsc-10 sensor.
tjoerd
by tjoerd
uquality wrote:
Sun May 23, 2021 8:00 am
Hi Uquality,
I currently have Schwalbe pro one 32's for the road and Cinturato gravel H 35mm for gravel and the bike does not feel twitchy for me at all. This goes for all surfaces acutally. Also have a size 54 with 110mm stem (42cm bars tho). Hopefully you get this sorted out quickly.
Cheers!
Tifosiphil
by Tifosiphil
Dubadai wrote:
Wed Apr 14, 2021 4:28 pm
I've been running 52/36 with an 11/34 that has gotten me up most things. Did a road climb on Sunday and on the 36/34 my cadence was down at 60rpm pushing 300W for 12minutes. So glad I had the dinner plate on there :lol:
uquality
by uquality
tjoerd wrote:
Tue May 25, 2021 11:01 am
Hi Uquality,
Cheers!
Dialed my position. Moved the seat forward 1.5cm and flattened my hoods and the bike feels like a dream now.
The Exploro has slightly more wheel flop than my old road bike which I had been mostly riding and that threw me off.
I feel great on both road and gravel wheelsets.
sham
by sham
JackieJunior wrote:
Mon May 03, 2021 10:45 am
Can I ask what your RTP frameset weighed before painting? I'm awaiting delivery of an RTP frameset in size 51 and would love to have some better estimates on weights as I will be keeping it as raw carbon for my build.
J.Guillem Orient 54 7.5kg
3T Exploro RaceMax 51 7.3kg
smartyiak
by smartyiak
JackieJunior wrote:
Sun May 16, 2021 8:07 pm
You did that with a spray can? Outrageous...that looks AMAZING! Love it.
So, I've decided to take a jump into gravel. Exploro on the shortlist, but:
1. Concerned that it's just too much like my road bike (S3) and
2. has anyone had an issue with the cutout and rocks? I've heard it mentioned as a concern, but I've never seen "real world data" to support that. I'd mostly be riding gravel, fireroads, forest service roads...maybe some easy single track connectors...nothing too outrageous.
3. Anyone bike pack with their's? I'd be looking at overnight...maybe three days; nothing crazy like 7-10days.
jmh
by jmh
basurper wrote:
Mon May 17, 2021 2:15 pm
You can always just put a magnet on the back of the pedal spindle. You can then align it with your cadence sensor that is easy to get out of the way. This is my preferred method on bikes without a powermeter.
