New Exploro RaceMax
sham
by sham
FlatlandClimber wrote:
Mon Nov 01, 2021 2:24 pm
The tires look gargantuan, like 3.0" fat bike tires. What is the frame size?
Tyres are Terravail Rutland 27.5 2.10" on a Size 51 frame.
J.Guillem Orient 54 7.5kg
3T Exploro RaceMax 51 7.3kg
alexneumuller
by alexneumuller
The problem is … that sometimes I order a bike …. and due to Covid and supply chain issue it takes a while for it to turn up.
So it was a very nice surprise when I came back from holiday. Now I just need to source some parts….Enve Stem and brakes calipers
3T Exploro - Bastion - Baum - Colnago - Cielo - English Cycles - Enve - Festka - ISEN - Standert - Open - Pegoretti - Pinarello - Specialized - Sturdy - Stinner - Spoon - Speedvagen - Vanilla Classic - Parlee
Strava
Instagram
kevinw
by kevinw
lovely - good luck sourcing the rest of the parts :-)
tjoerd
by tjoerd
scuddyflypaper wrote:
Fri Oct 29, 2021 6:55 pm
Hi tjoerd I feel the same it's serving as my road and gravel bike and sold an emonda slr to get it. Working out well
Truthfully even though it's maybe 1.5kgs heavier I am sure it climbs better... it's not even slightly in doubt actually it really does
On the road I am using Zipp Firecrest 303's which brought the weight down quite a bit. They're only 1300g+. I have them Tubeless which also helps
They could double as excellent gravel wheels but I went with the 3T 44/40... they are nice but too heavy I would have gone with 2 x Zipp Firecrest with different tyres road/gravel if I'd known
It's now 8.3kg in total including pedals size 56
Not amazing weight but not too bad for an aero doubling as capable gravel machine
I've got the schwalbe pro one tyres and AXS 2x by the way
I've done nothing else to it am wondering how else to shave off weight. Group set upgrade to Red maybe ... although I think that is problematic with the lack of a wide range cassette far as I understood it. Am really enjoying having that for gravel use then extending onto the roads and good higher speed capability
Hi Scuddy,
Thanks for your reply (must have missed it before)! What tyre size do you use in road setup?
As I live in a pretty flat country I'm thinking of trying 1x soon, thereby reducing weight. Further looking at lower weight wheels with tubeless and sizing my tyres down to 28mm/30mm. I don't want to go too crazy on spending for shaving weight off, would then prefer to eventually spend it on a dedicated road bike probably.
@alexneumuller really nice looking color combination, enjoy the build!
alexneumuller
by alexneumuller
kevinw wrote:lovely - good luck sourcing the rest of the parts :-)
I making progress.
Still need to source the correct stem.
Have ordered SRAM Mullet Cassette and Chain
Handlebar is the Enve AR one.
Strava
Instagram
CustomMetal
by CustomMetal
alexneumuller wrote:
Wed Jan 12, 2022 6:12 pm
I making progress.
Hope calipers? Which rotors?
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
alexneumuller
by alexneumuller
I making progress.
That is still an open question. Any suggestions?
Strava
Instagram
DHG01
by DHG01
Beyond the well known sound options (XT/XTR, etc.), Galfer are known to be light and perform well.
CustomMetal
by CustomMetal
Wed Jan 12, 2022 6:43 pm
I making progress.
If your using Hope calipers I would use hope rotors, especially for gravel. I am using that combo on the Saffron and they are lighter and thinner than the sram ones and look great with the Hope calipers. Plus they come in fun colours so you could go red to match the frame?
Bertha- TT 9.8kg
kode54
by kode54
I would use the nice Hope floating CL rotors, but their smallest size is 160. Love the colors.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
alexneumuller
by alexneumuller
Ordered the Hope Rotors ein 160mm. And have changed my mind on the stem/handlebar: Ordered the Syncros Gravel Creston iC SL X which is a one piece cockpit.
I do have a set of Enve G23 wheels.....but thinking of going more Aero style wheels optimised for 40-42mm tires......question is just which ones?
Any recommendation?
Strava
Instagram
emotive
by emotive
alexneumuller wrote:Ordered the Hope Rotors ein 160mm. And have changed my mind on the stem/handlebar: Ordered the Syncros Gravel Creston iC SL X which is a one piece cockpit.
Any recommendation?
3T Discus 45 | 40 wheels?
Hunt limitless 42?
emotive
by emotive
alexneumuller wrote:… I do have a set of Enve G23 wheels.....but thinking of going more Aero style wheels optimised for 40-42mm tires......question is just which ones?
Any recommendation?
For road with 28mm tyres, Enve 4.5AR or Hunt Limitless 60
alexneumuller
by alexneumuller
Any recommendation?
Hunt limitless 42?
Ordered the 45/40 …… let us see how long they take to arrive
Strava
Instagram
alexneumuller
by alexneumuller
No interest for road usuage the 3T
emotive wrote:
Sat Jan 15, 2022 9:34 am
Any recommendation?
Strava
Instagram
