Crux 2021
ceriks
by ceriks
Hi,
I am planning to replace the headset bearings in my crux in the near future now that the wet season in north america is mostly over. I ordered the lower from my local specialized dealer. For the upper I am going to use a wolftooth to avoid having the headset issues others have come across.
Could someone please confirm if the headset from wolftooth should be the IS41/28.6 or the IS42/28.6? Seems that the IS42 option only comes in premium, whereas the IS41 comes in premium or performance.
I've read on different forums and seems like some say the IS41 works, some says the IS42 works. I dont mind the price difference, i just want to make sure I order the correct one that is compatible.
Thank you
la85
by la85
Hey all,
Ive been looking at a 2024 Crux Expert which comes with Sram 1x Rival Groupset.
Can this simply be converted to a 2x system by adding a front derailleur and a 2x front chain ring?
If so can anyone please advice which front derailleur will accomodate a 48/31 chainring?
Cheers
CrankAddictsRich
by CrankAddictsRich
la85 wrote:
Sun May 26, 2024 8:48 am
Hey all,
Cheers
No.. You'd need to buy a crankset specific for a double.
I converted my Crus expert to a double, but I swapped to Shimano so I knew I was shapping everything front the jump.
BikeTyson
by BikeTyson
Hey all,
Cheers
You'll need to buy and install a FD mount. It's the same one as the Aethos. Your local shop can order one or search on PerformanceBike or similar. For a FD, you just need to match it with whatever crankset you are going to run. I'm not super familiar with SRAM but they have normal road and "Wide" versions for the AXS stuff. I think (definitely double check this) the Crux comes with a wide crankset, so you'd need the wide FD. And just swap out the chainrings which is pretty simple for SRAM. But definitely check which crank version you have now before ordering the FD.
BikeTyson
by BikeTyson
CrankAddictsRich wrote:
Sun May 26, 2024 11:06 am
Hey all,
Cheers
I don't think Shimano or SRAM have 1x or 2x specific cranksets. They're all interchangeable. You just swap out chainrings.
PixelMike
by PixelMike
ceriks wrote:
Sun May 26, 2024 2:41 am
Hi,
Thank you
I join in the question. I am in the same doubt.
Thank you.
CrankAddictsRich
by CrankAddictsRich
BikeTyson wrote:
Sun May 26, 2024 1:09 pm
Hey all,
Cheers
For some reason I thought SRAM 1x cranks were direct mount like MTB cranks, but maybe I'm wrong... I took it off my bike and sold it, didn't look to closely at it.
BikeTyson
by BikeTyson
Sun May 26, 2024 10:17 pm
Hey all,
Cheers
Some are direct mount, some have spiders. But all of the road group cranks have interchangeable chainrings so you wouldn't need new crankarms going 1x to 2x. Same with Shimano. I used to go back and forth between GRX 2x for gravel riding and 1x for cross.
Torgo
by Torgo
Been kicking around the idea for a while of adding a suspension fork to my Crux. Based on DJ wind tunnel, I wonder if the Lauf Grit https://www.laufcycles.com/product/lauf-grit-sl would "fit".
Anybody have any experience changing out to this fork? Any thoughts on how it would change the geometry?
FuelForThought
by FuelForThought
Hi,
Thank you
The linked woftooth and enduro products I posted previously will assemble a perfectly fitting headset for the Crux. I have over 5000 km on them with no issue.
viewtopic.php?f=4&t=161754&p=1808958#p1808958
PixelMike
by PixelMike
FuelForThought wrote:
Fri May 31, 2024 2:12 am
Hi,
Thank you
Hi,
Not so sure about that, the bearing included with the IS41/28.6 is this:
- ACB 3645 SS- 1-1/8" stainless steel, Angular Contact Headset Bearing (30.2mm x 41mm x 6.5mm: 36 x 45 deg) --> OD 41mm
However, the original Crux bearing is Specialized S092500002
- Integrated, Campy style, 41.8x30.5x8mm, ACB 45X45 --> OD 41.8
The WolfTooth IS41/28.6 bearing is 0.8mm smaller OD than the original.
I'm not really sure if -0.8mm OD is significant or can generate excessive head play, I would be grateful if someone could clarify this point. But I would say the correct one is the IS42/28.6 ---> https://www.wolftoothcomponents.com/pro ... 2897717283
cycleboyco
by cycleboyco
PixelMike wrote:
Wed Jun 05, 2024 7:26 pm
Hi,
Thank you
Hi,
Another vote for the IS42/28.6-went back to confirm that I have IS42/28.6, installed last fall, no issues, so much better than the stock headset.
ceriks
by ceriks
So from what I gather, it seems than both IS42/28.6 and IS41/28.6 have been used successfully and without issues...
ceriks
by ceriks
ceriks wrote:
Thu Jun 06, 2024 4:21 am
Follow up from this. I decided to see for myself and pick up both the IS41/28.6 (standard bearings) and IS42/28.6 (premium bearings) from wolftooth. Did some measurements and dry fittings in the frame, and the IS42/28.6 is the more exact match to the headset bearings specialized makes for the bike. The IS42/28.6 has an outer bearing diameter of 41.8 mm which is identical to the stock specialized headset bearing. The IS41/28.6 bearing does fit and I'm sure would work fine once the preload is applied, but there is a decent gap between the frame and the bearing which I would think is not ideal.
This is the correct match: https://www.wolftoothcomponents.com/pro ... 2897717283
farkdotcomuser
by farkdotcomuser
can a 48/35 sram red quarq fit without worrying about clearance issues to the chainstay or impacting max tire clearance in the rear?
