Crux 2021
cbro
by cbro
So, up on the stand it looks like the limiter on the SRAM AXS 2X setup with the regular width spindle is the distance between the inside chainring bolts and the chainstay, rather than the chainring teeth. Measures out at about 1mm with a feeler.
Seems like the options are:
1. Live with it, hope everything is stiff enough around that area to avoid issues.
2. Round down edges of those bolts, giving another 0.5mm or so of clearance.
3. Switch to the wide axle, giving a more comfortable 3.5mm of clearance (but wider Q factor).
ChrisRideLog
by ChrisRideLog
I got one more additional weight from a bike store, the first gloss colored frame.
Frame weight summary
Claimed frame weight by Specialized
725g | 56cm | S-Works Crux (12R)
825g | 56cm | Crux (10R)
Actual frame weight
780g | 56cm | S-Works Crux (12R) | Satin Carbon/Spectraflair/Gloss Abalone
790g | 56cm | S-Works Crux (12R) | Satin Brushed Liquid Silver/Gloss Black/Smoke Marble/Gold Diamond Dust
860g | 52cm | Crux (10R) | Satin Dusty Blue/Ice Papaya // Fork: 400g
870g | 52cm | Crux (10R) | Gloss Coral Lilac Fade/Carbon/Limestone/Papaya/Grey/Black
Looking forward for more input :beerchug:
Karvalo
by Karvalo
spartacus wrote:
Thu Oct 21, 2021 12:46 am
I already said this and was ignored so for the last time you can space out the shimano BB cups because the spindles are long enough to also work on ITA shells which are wider than BSA,
You're not fitting the spindle to the shell, you're fitting it to the cups. Are ITA cups themselves the exact same width as BSA cups?
Basscadet
by Basscadet
I appreciate all the responses to my question, this forum is such an excellent resource. I have the luck (or problem) of finding enjoying qualities in just about every bike I've ridden, seems it is impossible to combine those qualities in a single bike as those ride characteristics work against each other.
cerro
by cerro
bikewithnoname wrote:
Fri Oct 22, 2021 11:11 am
Basscadet wrote:
Fri Oct 22, 2021 2:32 am
What are your thoughts on this bike vs. Aethos with 28-32mm tires for riding that is entirely asphalt or rough, mixed-use paths? Already have a Caledonia 5 Di2 and Open UP Di2, want a third bike and can't make my mind up between the Crux and Aethos.
You have an UP, which is essentially the same as a Crux, you have a Caledonia which is essentially the same as an Aethos.
By all means get yourself a new bike, it's nice to have new things, but it's unlikely either of those bikes will offer anything new that is tangible (other than less weight in the case of the Aethos vs Caledonia)
UP vs Crux I can buy, but more 700 clearance and lighter weight on the Crux. But Aethos and Caledonia are 2 totally different bikes. Aethos is light, no special parts or integration and made to be fun and agile on road. The Caledonia is all integration endurance roadbike with pretty high stack and not as racy geo as the Aethos.
FuelForThought
by FuelForThought
cbro wrote:
Fri Oct 22, 2021 6:36 pm
Thanks for the info! What chainrings are you running?
cbro
by cbro
FuelForThought wrote:
Fri Oct 22, 2021 7:32 pm
I've got a 48/35 on there right now.
LegPower
by LegPower
Could you go with the integrated Red rings so there aren't any chainring bolts?
cbro
by cbro
LegPower wrote:
Fri Oct 22, 2021 8:54 pm
Good question, I'm not sure. This is with the Force 48/35 spider. All else equal, if those bolts weren't there the next-closest gap would be between the chainring and the chainstay, which is a hair greater than 2 mm.
Ridinghigh
by Ridinghigh
What about throwing a 1 mm spacer on the drive side spindle?
cbro
by cbro
Ridinghigh wrote:
Fri Oct 22, 2021 10:26 pm
I was thinking about that. I have a bunch of 0.5mm spacers. Is there a consensus on how many can be added before it interferes with full seating of the crank on the splines?
RyanH
by RyanH
I need to figure out why my headset is creaking...
Strava
Not for the sensitive types. My Instagram reviews
The Ex's: I've lost track...
Ridinghigh
by Ridinghigh
cbro wrote:
Fri Oct 22, 2021 11:12 pm
Wouldn't you just loosen the bearing preload ring? It definitely has 1 mm of lateral adjustment.
LegPower
by LegPower
Got my frame. Size 54 black / gold color.
ChrisRideLog
by ChrisRideLog
Actual frame weight
747g | 54cm | S-Works Crux (12R) | Satin Brushed Liquid Silver/Gloss Black/Smoke Marble/Gold Diamond Dust
