Crux 2021
So we've both made assumptions but mine is incorrect and yours isn't?
Have you tested the max tyre size you can fit on a Crux?
Thought not.
So are we both wrong or both right?
[ Removed by mod...seriously? ]
Thought not.
IG: RhinosWorkshop
IG: RhinosWorkshop
@Karvalo @ryanw
Keep it civil. You both need to learn how to discuss things without making it personal. Next person that can't figure out how to politely disagree will be going on holiday.
Anyone triede the clearence with a 1x sram setup.
i am going for a sram red 8bolt crank with quarq 5bcd 110mm
i ordered a 44T oval chainring(so 46 at biggest point)
and wondering if it will fit? anyone tested it yet or able to help me
Guys, chill. We'll very soon know the max tire clearance on a crux. Trial and error.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
And your assumption that you can't potentially fit 2.35" 650B tyres on a Crux is also wrong (since you haven't tested nor provided any evidence), so we're both wrong together
IG: RhinosWorkshop
IG: RhinosWorkshop
My frame arrived. The front has 63mm of clearance at the widest part for tires. The rear has 61mm of clearance at the widest point for tires. Hope this helps! I'll be working on cranksets tonight after the kids go to bed!
I'd guess you could fit a 700x50 in there with 5mm clearance on each side.
I'm thinking they said 47mm max because they wanted to leave more room for mud clearance. They did the same thing with the previous crux tire clearance.
Thanks
Gavin
Thanks
Gavin
Much appreciated.
I use Flickr for photos
IG: RhinosWorkshop
IG: RhinosWorkshop
The problem with a 700c tire usually isn't the clearance on the stays, but clearance to the seat tube.Gavin929 wrote: ↑Thu Oct 28, 2021 8:03 pmMy frame arrived. The front has 63mm of clearance at the widest part for tires. The rear has 61mm of clearance at the widest point for tires. Hope this helps! I'll be working on cranksets tonight after the kids go to bed!
Thanks
Gavin
I'm kind of scratching my head on this as I almost feel like I installed this wrong but with the Dub Quarq (3mm spacer DS) there's quite a lot of space with a 52/36 (FSA) chainset:
Here's with 50/34 MKV Rings:
I just tried the newest quarq dub dfour model with shimano dura ace 52/36 chainrings and it does not fit. The inside of the 36 tooth chaining will rub the frame. The teeth clear just fine. It's the actual inside of the chainring that rubs.
Is your crankset the quarq Dzero 5 bolt with 110bcd?
I'm guessing that shimano spaced cranks/chainrings will rub just like mine was with the 3mm spacer installed properly. Again, it's the actual chainring near the bolts that rub and not the teeth that touch.
I'm trying to figure out which crankset to get as I'm not sold on 48/31 grx for the riding I'm going to do. It's mostly the 31 tooth that I would like to be a bit bigger.
I've seen a 46 tooth on a red crankset installed on a new crux. You should be fine.mathias720 wrote: ↑Thu Oct 28, 2021 8:10 amAnyone triede the clearence with a 1x sram setup.
