Crux 2021
That is my issue as well.
And bigger the tire clearance, the worst it is.
Running 32mm road clinchers would be ok, but i feel they are not that live, like 25mm.
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
35mm Pirelli Cinturato TLR might be a good option, too, or even 35mm TerraSpeed.
Hardly any slower than Strada Bianche, easier to get them set up and more capable.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Fortunately I have two wheelsets so the Strade's would be strictly on road and maybe the odd farm track to link roadsFlatlandClimber wrote: ↑Wed Dec 01, 2021 10:07 am35mm Pirelli Cinturato TLR might be a good option, too, or even 35mm TerraSpeed.
- Moderator
I run them on my saffron and they are slow!!FlatlandClimber wrote: ↑Wed Dec 01, 2021 10:07 am35mm Pirelli Cinturato TLR might be a good option, too, or even 35mm TerraSpeed.
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
Which ever of the two you are referring to, they are not.
I mean, they are not slow objectively.
The TerraSpeed is the fastest knobby tire BRR has ever tested, 1W slower than the GP5000TL.
The Pirelli Cinturato are not a super fast road bike tire, but probably the most puncture proof, and still faster than most gravel tires for sure.
That is very interesting fact actually. Let's summarize below.FlatlandClimber wrote: ↑Wed Dec 01, 2021 6:05 pmThe TerraSpeed is the fastest knobby tire BRR has ever tested, 1W slower than the GP5000TL.
Gp5000 tl 25mm 8.3W https://www.bicyclerollingresistance.co ... 00-tl-2018
gp5000 tl 32mm 20W https://www.bicyclerollingresistance.co ... 5000-tl-32
terra speed 35mm 21W https://www.bicyclerollingresistance.co ... erra-speed
- Moderator
The cintutato in 35mm on the road is a bloody slow road tyre! Bomb proof, but not fast. If looking for a winter road tyre it works well in that you will always get home, but it won't be a quick ride. Been using the cinturatos for 3 years so well versed in them. Had 25,28 and 35mm versionsFlatlandClimber wrote: ↑Wed Dec 01, 2021 6:05 pmWhich ever of the two you are referring to, they are not.
Bertha- TT 9.8kg
Bertha- TT 9.8kg
- Moderator
I have a set of wheels that I run 5000TL 32 and Terra Speed 35mm and can tell you that Strava suggests there is a lot more than 1 watt in itreq110 wrote: ↑Thu Dec 02, 2021 11:22 amThat is very interesting fact actually. Let's summarize below.FlatlandClimber wrote: ↑Wed Dec 01, 2021 6:05 pmThe TerraSpeed is the fastest knobby tire BRR has ever tested, 1W slower than the GP5000TL.
Bertha- TT 9.8kg
Bertha- TT 9.8kg
The Pirelli 4S is a faster winter tire, but relatively fragile.CustomMetal wrote: ↑Thu Dec 02, 2021 11:33 amThe cintutato in 35mm on the road is a bloody slow road tyre! Bomb proof, but not fast. If looking for a winter road tyre it works well in that you will always get home, but it won't be a quick ride. Been using the cinturatos for 3 years so well versed in them. Had 25,28 and 35mm versionsFlatlandClimber wrote: ↑Wed Dec 01, 2021 6:05 pmWhich ever of the two you are referring to, they are not.
I can't say the Cinturato have held me back, when ever I rode them. Of course they are slower than a fast summer tire, but they are sturdy enough for gravel, and faster than most gravel tires on the road. That's all
I meant.
I'm gonna come out and say I think those numbers are wrong. I was going back and forth between bikes with 25c and 32c gp5000tl and there's NO WAY the 32's were 10w slower per tire. I don't even believe 5w per tire.req110 wrote: ↑Thu Dec 02, 2021 11:22 amThat is very interesting fact actually. Let's summarize below.FlatlandClimber wrote: ↑Wed Dec 01, 2021 6:05 pmThe TerraSpeed is the fastest knobby tire BRR has ever tested, 1W slower than the GP5000TL.
They were tested with 160gr inner tube. This has to hurt the performance of the GP5k more than the TerraSpeed. Otherwise I can't imagine how a wider, knobbed tire is within 1W of one of the faster road tires. Although the knobbies aren't especially tall, they still deform and that has to be more than 1W on tarmac.
- Moderator
It is! The solo KOM on our local chain gang loop was set on a pair of them bonkers fast but rolls over all the potholes
Bertha- TT 9.8kg
Bertha- TT 9.8kg
In my experience they're just as fast rolling as the narrower versions so that makes sense. I was tempted to put them on my "fast bike" but I suspect there's an aero penalty.CustomMetal wrote: ↑Thu Dec 02, 2021 4:10 pmIt is! The solo KOM on our local chain gang loop was set on a pair of them bonkers fast but rolls over all the potholes
- Moderator
Yeah I am changing to the 30mm on the new TRs as think that will be the optimum for my CLx50s on my crap roads and on an all road bikespartacus wrote: ↑Thu Dec 02, 2021 4:16 pmIn my experience they're just as fast rolling as the narrower versions so that makes sense. I was tempted to put them on my "fast bike" but I suspect there's an aero penalty.CustomMetal wrote: ↑Thu Dec 02, 2021 4:10 pmIt is! The solo KOM on our local chain gang loop was set on a pair of them bonkers fast but rolls over all the potholes
Bertha- TT 9.8kg
Bertha- TT 9.8kg
