New Diverge Thoughts?
- Moderator
Just released
https://www.bikeradar.com/news/2021-spe ... d-diverge/
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
68mm BB shell confuses me. Why won’t they adopt T47...are they planning their own standard with threaded internal cups?
tire clearance ++++
I watched some reviews on YT.. solid carbon yoke ? hopefully you can pass a di2 cable through still. I'm sure my LBS will get one so I will check it out. Not in the market personally as if I get another all road bike it will be Titanium (moots or bingham)
2024 BMC TeamMachine R Building
2018 BMC TImeMachine Road
2002 Moots Compact-SL- getting aero look makeover
2023 Pivot E-Vault - completed project, full Xplr package
So tall on small sizes.
Supporting gravel tire require tall fork. Then Future Shock require some (a lot of) stack height.
Now Specialized stuck on how to shrink the stack height of small sizes without reducing the head tube length into nothing and compromise headtube integrity.
So their small sizes have very tall stack height as a result. Therefore, it's simply not in my consideration because of the geometry.
What am I missing... isn't 68mm just good ol' English thread?TobinHatesYou wrote: ↑Thu May 07, 2020 11:12 pm68mm BB shell confuses me. Why won’t they adopt T47...are they planning their own standard with threaded internal cups?
yes I think it isrobertbb wrote: ↑Thu May 07, 2020 11:32 pmWhat am I missing... isn't 68mm just good ol' English thread?TobinHatesYou wrote: ↑Thu May 07, 2020 11:12 pm68mm BB shell confuses me. Why won’t they adopt T47...are they planning their own standard with threaded internal cups?
68mm Threaded bb is the normal and narrow BSA. It require external cup to place the bearing outward.robertbb wrote: ↑Thu May 07, 2020 11:32 pmWhat am I missing... isn't 68mm just good ol' English thread?TobinHatesYou wrote: ↑Thu May 07, 2020 11:12 pm68mm BB shell confuses me. Why won’t they adopt T47...are they planning their own standard with threaded internal cups?
This is inferior to wider bb standards such as bb86 (86.5mm wide) and T47 in term of pushing out chainstay to give way for wide tires in a short chainstay.
Specialized use flat solid right side chainstay to have the tire clearance. If they use bb86, bb386 or T47 then It could have use a wider chainstay than their flat version thus even shorter chainstay.
Wider is better. T47 with internal cups widens the shell to 86.5mm and that lends itself to better tire clearance. No need for a flexy carbon bar vs a stiffer carbon tube.
It's a step in the right direction with a threaded BB.
I'm honestly not that convinced how much stiffness a T47 offers over a 68mm BSA. I mean at what wattage does this really make any difference.
Further Jan Heine (arguably the godfather of wider tyres on road bikes) seems to think "planing" is a good thing.
https://cyclingtips.com/2017/06/cycling ... ss-matter/
https://www.renehersecycles.com/expert- ... stiffness/
I get this forum is all about the margins, but really, nobody here is going to be slower because their bike has an English threaded BB over a T47.
robertbb wrote: ↑Fri May 08, 2020 12:06 amIt's a step in the right direction with a threaded BB.
I'm not talking about BB flex. I'm talking about the bendy carbon bar used to improve tire clearance. That is going to lend itself to lateral chainstay flex because a tube would have been stiffer.
- Moderator
https://www.specialized.com/au/en/diver ... 96220-3149
Pretty keen on this spec.
Sent from my SM-N976B using Tapatalk
Using Tapatalk
Same frame as the pro model.. looks better than the pro with this paint too.Nefarious86 wrote:https://www.specialized.com/au/en/diver ... 96220-3149
Agree that it hits the mark in most categories(clearance/ mounts /storage /weight/ handling ) but for short people.. Enormous stack can't be fixed for size 49/52 which only have a 5mm difference. And futureshock stems pretty sure doesn't come with negative 17deg.
Sent from my Pixel 4 XL using Tapatalk
$16K for the top of the line S-Works bike and $6000 for the frame. Crazy prices!
How do the parts add up to $10,000 on the $16K bike?
Nevermind. I was on the Australia site for some reason and looking at Aussie dollars.
Way to kick a man when he's down
Welcome to our lives!
Not only that, but we also get very limited choices of colours/models.
