Another GRX di2 Question
d36
by d36
Is grx di2 rear derraileur just a rebadged xt?
Is there any real benefit apart from wanting to go 2x with a road fd?
Price difference is approx $200
Point
by Point
If I remember correctly from my research, the grx is very similar in looks to the XTR but acts more like the Ultegra RX derraileur in that it has a slightly less tensioned clutch than the XTR.
IrrelevantD
by IrrelevantD
It's closer to a rebadged Ultegra RX, which is no longer in the lineup.
The XT (M8000-GS) officially has a max front difference of 10T, Ultegra is 16T, GRX is 17T. Largest cog on the cassette is 42T for XT, and 34T for Ultegra and GRX.
Additionally, the cable pull for the MTB components is different. GRX is is fully compatible with Shimano road groupsets, with 600 and 800 series being 105/Ultegra equivilent 11-speed groups, and 400 series being 10-speed Tiagra equivilent.
TheRich
by TheRich
Point wrote:
Wed Nov 27, 2019 1:08 pm
Which should reinforce the idea that if you want to go 1x with Di2, use a mtb derailleur....along with the fact that it's designed to work with a big cassette.
ooo
by ooo
2x Di2 GRX RD-RX815 = RX RD-RX805 + longer cage + bigger tension pulley + stronger factory tension (can be readjusted on both)
1x Di2 GRX RD-RX817 = XT RD-M8050 + same cage and pulley + software removed any fd compatibility + different link to hanger
For 2019 products (XT/GRX/etc) shimano use new clutch grease, which can also be applied to older products, if you can find it.
(before 2019 shimano applied internal gear hub grease on clutch, now they recommend new grease for old mtb/road clutch derailleurs)
