FSA Omega crank (Topstone) chainline?
tomh79
by tomh79
I just measured the front chainline of my stock crank (FSA Omega 46/30) on my Topstone 105. Did measure multiple times...constantly getting around 46/47mm chainline - several (German) websites list a 43.5mm or 44mm chainline for this crank?!?! no info on the FSA website...does anybody know more? If the 46mm are correct - I could easily switch to GRX 46.9mm without noticing...
Marin
by Marin
In the middle between the rings?
tomh79
by tomh79
yes - middle frame to middle of small and large chainring.
fourfa
by fourfa
If your FSA crank is like mine, it's possible to have a longer spindle than is strictly necessary, and some spacers and a wave spring taking up the extra space. Move those around, and you can make dramatic changes to chainline. Perhaps Cannondale has done this? So the midline of the spindle is not exactly midline of the frame, to make more clearance for the rings around the chainstay?
But yeah, probably a good indicator for a GRX switch
tomh79
by tomh79
Good point. Will check.
tomh79
by tomh79
No spacers.
