Cervelo Áspero Gravel bike
Timely. The bottom bracket on my Aspero is creaking like a haunted house floor when I lay on the power. It's an Easton (to match the Easton crank), I'll take your advice on the BBsideways eightgSporco wrote: ↑Sun Aug 02, 2020 8:51 pmHonestly checkout the BBinfinite BBs. They are absolutely awesome and quality is top notch! I sprung for the ceramic and it spins forever and its nice and stiffPeabody wrote: ↑Sun Aug 02, 2020 8:41 pmJust got back from my LBS.
The Non-Drive Side bearing was totally fubar'd - no sign of water infiltration - just looks like a crap bearing.
Drive Side was completely fine.
Decided against the GRX crankset for now as I would like to swap out the BB for a Hambini unit. Unfortunately, he appears to be out of stock, will wait till I can order one of his units.
My LBS put a new bearing in while I was there (super awesome of them) and I am back on the road again.
Cervelo Aspero (7.75); Orbea Orca OMX (7.30)
Retired: S-Works Tarmac SL6, LOW// mki, Pinarello Dogma F10\F8, Lapierre Pulsium, TIME Fluidity, Wilier Cento1 SR, Ridley Noah, Cyfac Cadence, Cervelo S2\R3\R5, Felt Z25, Klein Quantum, Cannondale 2.0
I didnt have much luck with my Easton BB on my last bike. It was stiff from the start and was crunchy after 1000k
As Scooby Doo would say, "ruh roh." I just purchased the BBi for my Aspero but still have an Easton bracket on my Orbea, which is coming up on 1000k....
Awesome, did you rent to press tool from them? It works perfectly. Also, i cut my BB out using there recommend dremel bit for $11. I didn't like using the sockets to unthread them as i felt it would scratch the frame.
I'm close to a mechanical klutz, I can change cassettes or stems but wouldn't try a bottom bracket. Have to rely on the (very busy, booked a month in advance) professionals.
That stinks, if we lived closer I would do it for you. I haven't returned the tool yet. But I think we are on different coastsStendhal wrote: ↑Tue Aug 04, 2020 7:26 amI'm close to a mechanical klutz, I can change cassettes or stems but wouldn't try a bottom bracket. Have to rely on the (very busy, booked a month in advance) professionals.
Could use some sizing help from those that own Asperos. I'm currently on a Felt F3X (size 57) and am trying to decide between a 56 and 58 Aspero. I'm 184cm (about 6' 1/2") tall.
Stack
Felt = 587
Aspero 56 = 580
Aspero 58 = 605
Reach
Felt = 406
Aspero 56 = 397
Aspero 58 = 406
I'm currently running a 100mm/-8 stem on my Felt, which has a 20mm headset top cap, and I'm assuming an 8mm top cap for the Aspero in the following calculations. To best match my Felt setup with the 56cm Aspero would require a 110mm/-8 stem and 15mm of spacers. To best match my Felt setup with the 58cm would be a 100mm/-8 stem (same as my Felt), no spacers and I'd still be about 6.5mm higher with the bars on the Cervelo (which I honestly would not complain about). The problem is, my shop mocked up a 58cm Aspero next to my Felt (I didn't see the two side-by-side, unfortunately) and the owner said that the Aspero looked significantly bigger, noting in particular that the handlebars weren't as low (which the math tells me is true) and that the standover on the Cervelo was much higher, despite the numerical standover value on the 58cm Aspero actually being 1mm lower than my Felt.
I'm curious what size bike those around my height went with. Thanks.
Stack
Felt = 587
Aspero 56 = 580
Aspero 58 = 605
Reach
Felt = 406
Aspero 56 = 397
Aspero 58 = 406
Time VXRS Ulteam (7.16 kg)
viewtopic.php?f=10&t=120268
Im not your height; Im 5,7" But let me say this.. I come from the school of thought that you fit yourself to the smallest frame you feel comfortable in. Logic for this: You can always lengthen the stem, Seatpost and Forward/ Aft position.. However, when you size up you can only go shorter..savechief wrote: ↑Mon Aug 10, 2020 9:13 pmCould use some sizing help from those that own Asperos. I'm currently on a Felt F3X (size 57) and am trying to decide between a 56 and 58 Aspero. I'm 184cm (about 6' 1/2") tall.
Stack
Felt = 587
Aspero 56 = 580
Aspero 58 = 605
Reach
Felt = 406
Aspero 56 = 397
Aspero 58 = 406
At 5,7" barefoot I "could" have gone with a 51cm however the 48cm frame fit perfect and allows me to run a 100+cm stem for roadie mode and always go shorter for long days of offroad while scooting the saddle back..
That all being said, I feel the 56 would be the better choice over the 58.. The Aspero is prety much an R5 on steroids, slightly beefier frame with wider clearance tires.. Look at the new Caledonia, even that bike has more relaxed geometery than the Aspero.. Dare I say 1 bike to rule them all similar to the 3T and the Open which I put all in the same category..
I’m exactly the same height, and I’m on a 58 Áspero. I wouldn’t want to go smaller.savechief wrote: ↑Mon Aug 10, 2020 9:13 pmCould use some sizing help from those that own Asperos. I'm currently on a Felt F3X (size 57) and am trying to decide between a 56 and 58 Aspero. I'm 184cm (about 6' 1/2") tall.
Stack
Felt = 587
Aspero 56 = 580
Aspero 58 = 605
Reach
Felt = 406
Aspero 56 = 397
Aspero 58 = 406
Can you give me an idea of your current 58cm Aspero setup, such as saddle height, spacers, stem, etc? What aspect of the 56cm Aspero makes you say that you wouldn't want to go smaller?
Thanks.
Thanks.
I don't know the saddle height off the top of my head, but it has a 100mm -6° stem with a 1 cm spacer under it. If I removed the spacer it would closely emulate the fit of my road bike.
Build almost complete.
Currently sitting at 16.8lbs/ 7.62kg
Raodie Mode Build Spec:
48cm Framset
Sram Force AXS levers
Sram Force AXS calipers
Sram Crossline 160mm rotors
Sram Red AXS Crank arms
Wolftooth 44t Chainring
Bbinfinite ceramic BB
Sram Force AXS RD with Wolftooth roadlink
Sram Force AXS 10-36t cassette
Easton EC90 SLX 38cm Handlebars
Uno lite with Ti bolts 100mm
Niner RDO 0 setback seatpost
Selle Italia SLR Ti saddle
Enve 4.5AR with Industry 9 hubs
JL thru axles
Gravelking Slick 32mm
Shimano ES-600 pedals
Chinese Carbon cages
I would like to get it to 16lbs/ 7.2kgs with farsport wheels and a lighter seatpost, but i think thats about as light as it will get and I am pretty happy with that
Need some seatpost recommendations
48cm Framset
JL thru axles
That thing's a beauty! Are you ever bothered by the gear gaps in the cassette? I tried 1x in roadie mode but had to go 2x because the gearing was so wacky. I recommend the Ritchey Superlogic post. It's about 145g and has a lot of built in flex to take the edge off.gSporco wrote: ↑Wed Aug 12, 2020 4:26 amBuild almost complete.
48cm Framset
JL thru axles
Yes, it's taking a lot of getting used to with the gaps. Im cadence sensitive and my original 2x setup from my Niner was a dream. Then chasing simplicity and the clean look has brought me from the eThirteen 9-46 then eagle 10-50 both with eagle derailleur and they were almost unbearable for roadie use (keeping the later for trail days).Bikedude135 wrote: ↑Wed Aug 12, 2020 7:49 amThat thing's a beauty! Are you ever bothered by the gear gaps in the cassette? I tried 1x in roadie mode but had to go 2x because the gearing was so wacky. I recommend the Ritchey Superlogic post. It's about 145g and has a lot of built in flex to take the edge off.gSporco wrote: ↑Wed Aug 12, 2020 4:26 amBuild almost complete.
48cm Framset
JL thru axles
The 10-36 is a lot better in the low gears with the 1 tooth jumps but climbing gets funky.
Thanks ill check out the Ritchey seatpost
