New Cervelo Áspero Gravel bike
dmtevo
by dmtevo
IrrelevantD wrote:
Mon Dec 16, 2019 3:40 pm
dmtevo wrote:
Mon Dec 16, 2019 2:38 pm
Could this be the "do it all" bike?
I'm thinking of getting one of these to replace my aluminium gravel bike and my carbon aero road bike. The geometry looks like an endurance road bike with a capability of using different wheel sizes.
Any thoughts?
Yes.
I bought a 54 Aspero and was able to replicate the position on my size 56 Allez Sprint. My primary intention in going with the Aspero was to replace my road and CX bikes and have this be my one bike for all with 80~90% of use being on the road.
I put Conti GT5000TL 28s on it and leaving the chip in the forward position (lower trail), it feels every bit as nimble as my Sprint did. Longer wheelbase and lower BB makes it feel more stable cornering at speed. It might be a touch slower in a straight line, but that could also be due to rolling resistance as 700x28's are about 3mm wider (@31mm) on the Easton AX rims than the rim brake HEDs I had on the Sprint. Power transfer is every bit, if not more stiff and I notice that most when climbing. Biggest downside for me on road is the 50T front ring limitation. It's relatively flat where I live and I have a tendancy to grind at ~80RPM in big gears. Not a huge issue, but I do notice I'm down in the 11-13T cogs more.
As for gravel, coming from using a Trek Crockett (cx) with 700x38's, the Aspero is much more stable with 40s at speed. I have also done some light and intermediate single track, and while it's not quite as nimble as the Crockett in tight cornering, and the lower BB has given me more pedal strikes especially on rocky climbs. That being said, I have bested my previous PRs on every trail I've taken it on so far.
The only place that I can see that it will have issues is going to be as a bikepacking rig. I'm sure you can find some way to give it cargo capcity, but it wouldn't be ideal. I don't do any of that, so it works great for what I wanted.
Thanks for the feedback, excellent!
thefuzzycow
by thefuzzycow
LegPower wrote:
Fri Sep 27, 2019 6:26 am
It's prob worth noting that I've got a second set of wheels - DT Swiss XMC 27.5. They came in at 1360g for the pair. The only bummer with the Aspero is that I needed to go with 48mm tires instead of the 2.1" Thunder Burts I had on there before.
Leg, so I just sold my Exploro (sad day, didn't want to but hate I have no offset for seatpost options and proprietary seatpost. Anyways...) I have a set of Reynolds ATR 650 wheels that I used on trial riding that I fit with Thunderburts. Rim width put aside, Have you tried to see how snug the fit is on the Aspero with the 2.1" tires?
Thanks,
Fuzzy
"moo"
Cervelo Aspero
Specialized Epic
Quintana Roo pr5
IrrelevantD
by IrrelevantD
thefuzzycow wrote:
Mon Dec 30, 2019 8:12 pm
Thanks,
Fuzzy
I'm running 650x47 WTB Senderos on mine for trail use. They measure about 48mm on a set of Mercury wheels with 30mm internal. You could probably fit 50mm with about 3~4mm clearance on the DS, but any wider than that and you'd risk rubbing the stays if you got any caked on mud or an out of true wheel.
Narrower rim, like 24mm internal, maybe you could squeeze a 2.1, but I want to say anything bigger than a 1.95 is going to be extremely tight.
thefuzzycow
by thefuzzycow
IrrelevantD wrote:
Mon Dec 30, 2019 8:26 pm
Thanks,
Fuzzy
Right on. Good info. My ATR's are 23internal, 32 ext. I'm intrigued. If conditions are anything other than dry or morning dew, I probably would just ride my mtb. I'd keep the 2.1 or larger tires for dry trail.
"moo"
Cervelo Aspero
Specialized Epic
Quintana Roo pr5
emotive
by emotive
Thanks,
Fuzzy
My ThunderBurts measure 52mm on my old 22C inner width rim and 54mm on my newer 28C inner rims. I’m now riding Maxxis Maxxlite 1.95 which measure 49mm on the 28C. About 80g lighter and well suited to dry trails.
IrrelevantD
by IrrelevantD
emotive wrote:
Mon Dec 30, 2019 9:46 pm
If they measure 49mm you should be fine, but personally I wouldn't go any bigger than that. I will also say that if you get a completely flat tire, a 650x47 will rub on the chainstays. There is no riding it on the rim.
thefuzzycow
by thefuzzycow
Thanks,
Fuzzy
Be it that my ATR's are 23mm inner width, I'm curious to see what the clearance would be with a 2.1 set up. With the recommendation of 4mm of clearance around the tire, I could see a 2.1 working with certain wheel/tire combinations. 4mm=0.16 inched On dry day of trail riding, it shouldn't be a huge issue. If I get a flat, it's time for hike-a-bike back to the car anyway!
"moo"
Cervelo Aspero
Specialized Epic
Quintana Roo pr5
VTR1000SP2
by VTR1000SP2
Rode on a damp day, picked up a lot of grime, found this caused by buildup between the NDS crank arm and the BB shell. I’m running a Shimano crank setup.
Anyone else have a similar experience?
IrrelevantD
by IrrelevantD
VTR1000SP2 wrote:
Tue Dec 31, 2019 7:11 pm
Rode on a damp day last, picked up a lot of grime and found this caused by buildup between the NDS crank arm and the BB shell. I’m running a Shimano crank setup.
Ouch. That's painful to look at. Haven't seen that before. I did have my factory BB bearings disintegrate on me, which sent my big chainring into my chainstay.
VTR1000SP2
by VTR1000SP2
IrrelevantD wrote: Ouch. That's painful to look at. Haven't seen that before. I did have my factory BB bearings disintegrate on me, which sent my big chainring into my chainstay.
Sorry to hear about your issue, was it due to lateral misalignment in the shell?
On that same ride, I had a bad case of chainsuck which took a big old chunk of carbon with it. I going to have it repaired but am waiting for confirmation from Cervelo if a repair will void my warranty.
IrrelevantD
by IrrelevantD
VTR1000SP2 wrote:
Tue Dec 31, 2019 8:39 pm
Yea, my guess is the bearings were misaligned in the shell from the factory. I thankfully had an 8mm Allen bit with me and was able to shift an NDS spacer on the drive side and limp back home. when I took it apart balls went everywhere. Shop replaced them with some Enduro ABEC-3 under warranty. Not the best, but probably better than what Cervelo had in there.
ryanw
by ryanw
I'd add a spacer or 2 on the NDS spindle to stop that from happening it it was my bike.
I don't rate Kogel at all after servicing some of their BBs and pulley wheels.
Allez Sprint Disc - 7.60kg
SL7 S-Works - 6.73kg
www.rhinosworkshop.co.uk
IG: RhinosWorkshop
VTR1000SP2
by VTR1000SP2
ryanw wrote:I'd add a spacer or 2 on the NDS spindle to stop that from happening it it was my bike.
I will be adding micro shims when I reassemble.
I usually use Hawk BBs but got this Kogel BB for a good price and gave it a go. Wonder if the NDS sleeve has a thinner flange than other brands of BB.
simoncx
by simoncx
ryanw wrote:
Tue Dec 31, 2019 10:47 pm
I've had the same experience with kogel, never again. While the crank is off make sure to pull off the plastic dust shield and clean inbetween the shield and bearing because its a magnet for crap to collect behind.
VTR1000SP2
by VTR1000SP2
What experience exactly? Just curious on the specifics.
