Cervelo Áspero Gravel bike
itapersita
by itapersita
Does anyone have a Token ninja BB and red crank arms? What spacer did you install? I have mounted the 2mm that comes with the BB
mcou
by mcou
Anyone tried both Force AXS XPLR and Ekar?
I’m about to take delivery of an Apex build and will be doing a groupset swap as well as adding a set of Hunt wheels.
Plan is for an 80/20 road/gravel n=1. I’m settled on 1x but torn between the two groupsets. Cost isn’t a factor as the difference is about £100 on current deals. I’ve had and liked campy shift logic before, never done electronic.
As I see it Ekar has the more suitable gear ratios for my needs (13spd, 40t/9-42). SRAM gearing is comparatively less versatile (9-36 not ideal for gravel, 10-44 not ideal for road), but has the benefit of wireless/electronic.
I can also get an XDR freehub from Alexrims to use the stock wheels as a second set, but I emailed and they don’t make a N3W freehub body (I was the first to ask apparently).
I know I can’t go wrong with either but that doesn’t stop me agonising over it!
gorkypl
by gorkypl
Campy is top-end mechanical, Sram in 1x is as good as electric shifters can be. I earn for living sitting by a computer so I don't want any electronics on my bikes - but if you have no such reservations it's hard to argue with cold precision of electric shifting.
For 80% road i would see some benefit in tight spacing of Campagnolo cassette though.
Fuji Cross 1.5 - Shimano 105 5800 | Cinelli Superstar Disc - Record 12s | Custom steel Karamba - Ekar 13s
IrrelevantD
by IrrelevantD
mcou wrote:
Fri Oct 28, 2022 4:56 pm
Haven't tried Ekar, but I have Di2 on my Aspero and AXS on my MTB. I like Di2 better. Just feels a touch crisper and more precise. If you haven't tried both, you'd never notice though.
Brooks123
by Brooks123
Hi guys! I have the stock Easton seatpost stuck fast in my Aspero. I tried to ask around for suggestions on Facebook group, and guys recommended to use WD40 and/or boiling hot water. No luck with applying WD40. Has anyone tried applying hot water? Will the paint come off? Any other suggestions for removing stuck seapost?
nismosr
by nismosr
I Build an Aspero with Force xplr 1x this summer with zipp 303s .
2020 Colnago C64 Mapei-SR12 EPS-WTO 60
2021 Basso Diamante SV-SR12 Disc EPS-WTO 60
2023 Colnago G3X-SRAM AXS Force-Levante
rfhb3
by rfhb3
[/quote]
[/quote]
nice bike - could you tell me please what tire size/width this is? I'm currently looking for a Aspero with Zipp 303s but I'm unsure what the max tire width would be. 42mm? Or could 45 still fit in?
caad4rep
by caad4rep
Brooks123 wrote:
Fri Nov 04, 2022 4:07 pm
Try to find a good penetrating Oil and let that work it's way in for a day or two. Worst case scenario would be to crush the seatpost and hope that works it free
caad4rep
by caad4rep
caad4rep wrote:
Sun Nov 06, 2022 2:52 pm
Another option, loosen the bolt and go for a ride, just don't get too far from home
mb2243
by mb2243
Anyone have any experience to say if you can go to a 46t 1x chainring if you are using a Sram Wide crank?
nismosr
by nismosr
rfhb3 wrote:
Fri Nov 04, 2022 10:46 pm
[/quote]
[/quote]
tires on this are 38mm gravelking
ff119
by ff119
mb2243 wrote:
Mon Nov 07, 2022 2:26 pm
I'm told 44t was the biggest you could fit
wheelie
by wheelie
nismosr wrote:
Fri Nov 04, 2022 4:20 pm
Weight with this setup? Which frame size is it? 54 or 56?
Thanks!
2020 Cervelo Aspero Apex 1 Mid Olive/Dune ----> Burgundy/Dark Orange
2022 Scott Addict RC10
lukedunk
by lukedunk
Mine (Aspero 5) came built with SRAM Rival Wide with a 46t.
I'm swapping to GRX now, but rode it once with the supplied setup and it was fine.
nismosr
by nismosr
wheelie wrote:
Sat Nov 12, 2022 1:04 pm
Thanks!
size 54cm .. 17lbs
