Any Old School (Looking) Frames That Can Be Modernised?
Point
by Point
Just wondering if anyone knows of any older style steel, alu (looking) frames that'd be suitable for modernizing for gravel/commuting/general abuse. Presumably it'd be easier to go custom but just wondering if there's anything out there that could meet my criteria?
Looking for something that hopefully has:
  • Internal routing/full cable housing
  • 12mm axle's
  • 1 1/8th or tapered steerer
  • This is weight weenies, so the lighter the frameset the better.
  • Wide(ish) tyre clearance 35mm +
  • (Non essential) - Single speed compatibility
Essentially looking to build something similar to the Speedvagen GTFO, unfortunately can no longer buy framesets from them.
https://images.app.goo.gl/aTiW2MWoM2vBYinw7
Road - Burls Custom Ti
All Year - Rove ST
Gravel - Carbonda CFR 696
Instagram
Marin
by Marin
Huh, old frame with 12mm axles and tapered steerer?
If 2 years counts as old for you, maybe.
CarlosFerreiro
by CarlosFerreiro
I like the look/idea of a Lemond Poprad, but haven't ridden one.
But yes, external cables and QR there.
Point
by Point
Marin wrote:
Fri Jul 12, 2019 11:07 am
Which is why I included the Old school "(looking)" part to my post. As in more retro styling, steel tubing, lugged, horizontal top tubes etc... Doesn't neccesarily need to be and old frame.
Seen things like:
Ritchey - Good materials, weight, external cables not ideal (wanting for bike packing etc so straps can be problematic)
Kona - Standard tubing, not fancy, heavier, internal or full cable housing is better, mounting points etc.
All Year - Rove ST
Instagram
Point
by Point
CarlosFerreiro wrote:
Fri Jul 12, 2019 12:59 pm
This looks good, 20mm isn't fundamental. Will look more into this thank you!
All Year - Rove ST
Instagram
Marin
by Marin
My frames all have external cabling for simplicity and attaching bags is not a problem.
The Ritcheys are excellent BTW.
Point
by Point
Marin wrote:
Fri Jul 12, 2019 1:26 pm
Ahh yes, I should’ve said no top tube routed cables, down tube routed I don’t mind. Good to know though. That’s unfortunately where I’m a bit put off with the Ritcheys.
Really liking the look of the Lemond Poprad Disc, shame they’re like hens l teeth to find.
Anything of similar ilk with good tyre clearance would be ideal.
All Year - Rove ST
Instagram
ALAN Carbon+
by ALAN Carbon+
Have you considered the All City Cosmic Stallion the Curve GXR (aka the Kevin of Steel) or the Niner RLT Steel?
Sent from my ONEPLUS A5000 using Tapatalk
Alexbn921
by Alexbn921
Miyata 1000. Nothing will have thru axles.
Ride fast Take chances
NickJHP
by NickJHP
Have a look at the Bombtrack Hook 2.
mentok
by mentok
All City
Ritchey
Black Mountain Cycles
Crust
Surly
Soma
WinterRider
by WinterRider
A joy to ride.. 853 steel is excellent. Mine left in favor of Ti.. and the name plastered ahead of the Poprad model.
Great bike via Trek.
Litespeed 2000 Appalachian 61 cm
Litespeed 1998 Blue Ridge 61cm
Fitness rider.. 1 yr from seven decades age.
That is my story and I'm stick'n to it.
tandemracer
by tandemracer
