Identifying a freehub
PH123
by PH123
Hello,
Can someone help me identify this freehub?
I know it is made by Bearhubs.
It is from the Cinelli Zydeco, but is broken and I need to replace it. It needs to be the same type - with af 13 mm screw to lock it onto the wheelhub.
Two local bicycle -shops says they can't order it. So I basically have to locate it online and buy it. I have looked all over the web, but I am having troubles to locate the exact same type of freehub.
https://drive.google.com/open?id=0B-lJm ... BTaXJOQ0x3
https://drive.google.com/open?id=0B-lJm ... ZvU3Iybmlj
https://drive.google.com/open?id=0B-lJm ... 1KTmtyM2NJ
https://drive.google.com/open?id=0B-lJm ... 1zZkw0dG5j
PH123
by PH123
Correction. It is 16mm allen key that is needed to lock it onto the wheelhub.
