BB86 compatibility? Easton EC90SL crankset and any BB86?
Point
by Point
As title really.
I'm in need of an upgrade for my TCX and considering the EC90 SL crankset, but I'm a little conscious of the Easton BB price being quite high and wonder if I can use an alternative, presumably all BB86 bb's are the same? Providing the one I get accomodates a 30mm axle?
spdntrxi
by spdntrxi
~$50 bucks for a BB is high ? I installed the cups on the BMC that I am in the process of building. I plan to use THM cranks which are 30mm
low $40s on fleabay
prebsy
by prebsy
There aren't a ton out there that are 30mm bb86s. The easton bb86 can be found for ~$40 no reason not to do that. The other one that comes to mind is the rotor 4130 which is in the same price range.
Point
by Point
spdntrxi wrote:
Wed Apr 10, 2019 6:39 pm
low $40s on fleabay
US.
UK pricing is ish £60 : $79. It's not horrific. I'd just like to know if there are any cheaper alternatives.
Point
by Point
prebsy wrote:
Wed Apr 10, 2019 6:40 pm
Thank you, I'm starting to think I'll just stick with the Easton in that case. I can't imagine I'd be changing it too often anyway.
motorapido
by motorapido
GUB and Tokken do some decent BB386 for 30mm axle, the two sides screw together for good alignment and locate in the frame on O rings. should give a well aligned creak free solution.
I'm currently running my Gub BB386 30 with adaptors for a 24mm Axle FSA K force crankset, but i now have an Easton EC90sL crankset waiting to go on. Just need to pull the cranks and adaptors and it will fit straight in.
ms6073
by ms6073
While by the OP's economy of scale, the prices are thru the roof, if longevity and reliability are among the requirements, then consider Hambini or BBInfinite.
ChiZ01
by ChiZ01
Point wrote:
Wed Apr 10, 2019 6:49 pm
actually the bearing life will be short, BB86 is designed for 24mm spindle
Point
by Point
ChiZ01 wrote:
Thu Apr 11, 2019 9:14 pm
That's ultimately been my realisation. Looks like I'll have to go down another route. Thank you all for your input.
Noctiluxx
by Noctiluxx
I just ordered a 2x Praxis Zayante Carbon crank for my Giant Revolt. It can be set up as a 1x or 2x with multiple chainring options. Its a little lighter than a Dura Ace crank and according to Praxis, stiffer. Price sits between Ultegra and Dura Ace.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Giant Revolt Advanced 0
