any way to build back tread on MTB shoes?
Catagory6
by Catagory6
wearing down the tread. exposing cleat when walking
PJCM
by PJCM
There's this old article whereby a guy ground off the old sole and used a Sidi SRS kit to rebuild it. I'd probably look at the red rather than yellow version though, as the yellow ones on my Sidi Spiders have worn fast.
https://tandemgeek.wordpress.com/2010/0 ... nkenshoes/
Catagory6
by Catagory6
PJCM wrote:
Sun Mar 03, 2019 11:22 pm
thanks for the link. maybe that kind of total overhaul is for later on down the road.
i was thinking something like glueing/screwing old tire tread onto the existing shoe treads (i guess its called knobs?)
RussellS
by RussellS
I have some Carnac mountain bike shoes. I thought I wanted some more room around the cleat. So I cut away the sole, tread around the cleat. And then decided that was bad. So I filled in the tread again using epoxy or maybe GOOP brand glue. I think it was the GOOP brand glue but not positive. Maybe it was epoxy. The filled in, new tread is as hard or harder than what I cut away. So its just like new. Any hard drying epoxy or glue will work to replace the tread on your shoes.
https://www.menards.com/main/paint/adhe ... 05&ipos=26
Menards has Shoe Goo too.
https://www.menards.com/main/paint/adhe ... 91&ipos=27
Thought about it some more and I am positive it was EPOXY. Some kind of epoxy I bought at Menards or maybe Home Depot. Mix it up and use it small kit. It worked perfectly to replace the hard sole on my shoes I foolishly cut away.
NickJHP
by NickJHP
I use Shoe Goo to build up the soles so that the cleat doesn't contact the ground when walking. I also use Shoe Goo for filling cuts in the tread of bike tyres.
ChiZ01
by ChiZ01
shoe goo is like duck tape in liquid form
