Specialized Pathfinder tire
jever98
by jever98
Hi there,
Looking for opinions on the Specialized Pathfinder tire. Looks like a nice combination of slick center and knobbly outer edges.
Thanks for inputs.
No longer in the industry
1swiftvelo
by 1swiftvelo
Been knocking out the miles on them. Fast on the pavement with good drip in gravel. Highly recommendable.
jever98
by jever98
Thanks! Are you running 38s or 42s? Can you advise how they come out width wise?
1swiftvelo
by 1swiftvelo
Running 38s. Using Roval slx24. At 30psi they are 39.2mm 40psi same. I’m going thru and measuring all tire/wheel combos that come thru the shop currently. I’ll have wheel and tire measurements at 30/40 psi.
jever98
by jever98
I just got some Pathfinder 42s and put them on Mercury wheels, hookless 25mm ID. Came out 42mm at 3.5 bars. They look nice - can't wait to test them!
Briscoelab
by Briscoelab
They look like agood tire, but are a bit heavy. Should have good flat protection though. I'm going to be getting some 38's soon.
I so wished they would have kept making the "33mm" Trigger, that was a super fast gravel tire that was quite wide on an internal width rim >21mm.
wheelzqc
by wheelzqc
They are not light but in the range of other knobby tires ?! @480g for 38s. I find the Panaracer's are at the lighter end @ 420g and roll good enough. I wonder how the pathfinder rolls on road, gravel and trail compared to the GravelGrinder.
romanmoser
by romanmoser
These were used to lead Colin Strickland to Victory on DK 200 this year I think
In 42
