Gravel tire rolling resistance tested
Slightly concerned about the mounting of the Getaways, no problem at home, but if I'm out on the trail and need to put a tube in, that's gonna suck. I've had to put a tube in a TS before and was rolling again in no time, easy peasy.
The important thing is though, once the tire is stretched, installed & ridden you generally won’t have any difficulty managing it on the side of the road if you get a flat and need to put a tube in. The tires stretch into shape and become much easier to get on and off, after a short time.
https://bikerumor.com/exclusive-new-tub ... e-quality/
The challenge Strada Bianche HTLR are definitely winners. I have now used them for 1000k - 80% road/ 20% off road. They obviously won't work in deep mud, loose sand, loose rocks or very coarse gravel. They are slicks after all.
But they are comfy (36c), super fast, and puncture resistant enough for pointy rocks, and really bad roads.
Their biggest weakness is grip.
I just used them for a bunch of road riding in Andalusia, and on the super steep pitches found in the valleys, they lose traction very easily.
Also, when you brake hard, they tend to slide a lot more than a proper road tire.
Not a perfect tire, but a really fast road+ tire.
Looking forward if the Getaways perform equally well, with better grip and better off-road performance.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
The Strade Bianca Pro will definitely feel nicer and most likely roll faster than the GK slicks. But make sure you get the pro, which are handmade, vs the standard which are vulcanized and don't feel, roll or look as good as the handmade models.
I have a set of the Strade Bianche Pro in 30mm which I've barely ridden, but compared to my previously-mounted GP5K TL 28mm (which blew up to roughly 29.5mm) I'd say the difference (sorry for the tired car cliche) is similar to a Grand Tourer vs a straight Sports Car. The Challenge has a lot of performance built into it but it's just more comfortable and nicer to look at, while the GP5K TL is pure performance. Have a set of 32mm GP5K TR incoming so will see how those compare.
How is the cornering performance on the Strada Bianca Pro HTLRs?FlatlandClimber wrote: ↑Tue Feb 22, 2022 3:08 pmTheir biggest weakness is grip.
I've got a second wheelset for my gravel bike that has GP5000 TL 700x28mm tires at the moment. No doubt a great tire, but I now have a dedicated road bike so I'm thinking of switching these skinny GP5000s out for larger road+ tires. I'm strongly considering the Strada Bianca Pro HTLRs in 700x36mm.
Edit: Just saw yinzer's reply just above mine, which is very informative in comparing GP5000 vs. SBP
I was looking at the GP5K vs Challence Strada 30s for my "country road" / travel tires to replace my g-one speeds. The GP5k looks to be grippier, but also more prone to picking up something sharp as the rubber looks to be less durable.
Also, tried the Corsa Controls here, but they flatted in the first outing when the tread picked up some glass. Replaced first tire and the other tire flatted the next ride. It's just wide enough and square enough to pickup things (GK SKs do the same thing)
That's good to hear, thanks. Gonna give 'em a try and keep the set of TSs I have on hold.warthog101 wrote: ↑Tue Feb 22, 2022 8:29 amThe important thing is though, once the tire is stretched, installed & ridden you generally won’t have any difficulty managing it on the side of the road if you get a flat and need to put a tube in. The tires stretch into shape and become much easier to get on and off, after a short time.
Got my Getaways:
Installation:
Pretty tough to get them on the bead. Took me a cool 30 minutes. The biggest Problem was the thread laying flat, so it was super tough to push the bead into the rim bed.
Getting them set up tubeless was okay. Some bead leakage early on, but hopped into position quite quickly and kept tight on around 80ml of sealant per tire. A little more, than I'd usually use, but knowing the Strada Bianche, these tires are pretty thirsty.
Weight: 460g each.
Width: after the first ride, they were 39.9mm rear, 39.6mm front, on 25c internal hookless Zipps,
Ride: I usually do the maiden ride on too much air pressure, in order to compensate for potential pressure loss.
Comfort therefore is hard to judge.
However, they are really, really good. Fast on tarmac, good (not great) grip, and well capable of going off-road. I have my tire Test loop, with around 50 road/pavement, and 50 off-road, including sand, mud, fire road, chunky gravel, really beat pavement, forest paths and because of massive rain fall, even going through a river (1foot deep water with very light current). They mastered all of that pretty well, and I could have ridden them harder than I did.
Really wanna test them on the weekend on a long ride, but they feel like winners so far!
Installation:
Weight: 460g each.
Sounds great, thanks for the review.FlatlandClimber wrote:Got my Getaways:
Installation:
Weight: 460g each.
Mine are on the way but I'll be waiting until I get my LB WR50s first. They are prob still another month away.
I like the look of that bag too.
What brand/model is it?
Thanks.
It's the Apidura Racing Frame bag.
