The only thing to really keep track of is if tires are tested with butyl tubes or not (as you discovered). If tested tubeless, or with a latex tube, the results are no different. This is why I test with latex tubes. Butyl tubes typically add 3-4W per tire for "real world" rolling resistance.FlatlandClimber wrote: ↑Mon Nov 08, 2021 7:43 pmMight be, but several of these tests were conducted within a short period of time. I guess there are bigger factors playing a role here.
As far as comparing across tests goes, obviously one can't compare absolute values. However, relative rankings and percent difference should hold across the different protocols. It's always good when there's at least one, or ideally more, tires to compare across tests, to act as a "guide".
In other words, there shouldn't be any other "bigger factors" at play...assuming a particular test doesn't completely "stuff" their testing.
