11 speed wide cassette that are light.
pdlpsher1
by pdlpsher1
MichaelB wrote:
Thu Feb 28, 2019 11:20 pm
@ pdlpsher1 - can you provides pics at each extreme as I reckon my setup is also done ‘properly’ , but any additional insight will be appreciated
Edit : Shimano specs being conservative show total capacity of the RX800 is 39T (e.g. same as my setup) , but the setup from pdlpsher1 is 45T total, and that’s waaaay over, so keen to see what the secret sauce is :P
There's no secret sauce. The GS/RX RD has a long enough cage to acommodate a big total capacity. Properly adjusted B screw and with the right chain length, the chain is not too tight on the big/big and not loose on the small/small.
Cattiy
by Cattiy
Also want a 11/12T -42 cassette that is as light as the XX1 cassette for my road bike 1x project. 10T is too rough and loud on the road. Fine on gravel for me. Otherwise the XX1 is a peace of art. I was very disappointed with ETAP AXS options for the road.
Maybe the new Force groupset in April will have better options.
spdntrxi
by spdntrxi
pdlpsher1 wrote:
Fri Mar 01, 2019 9:52 am
very true.. my XTR 11-40 got installed on 650b wheelset #2 w/fenders ( required right now with all the rain).. no problem with the 40 and plenty of b-screw left. Which is good because 650b wheelset #1 will be an XX1 10-(44 wolftooth) WTB byway w/o fenders.
I do wonder if my clutch tension is set a little too high. When I engage the clutch occasionally the di2 wont shift... but always shifts with the clutch off. (RX-805) This never happened on the smaller 11-34 cassette. I'm eyeing to switch to XTR 2x setup now, tempted to go 1x.. then I would really need a 50 cassette at some point, because I dont want a tiny front ring.
Frisco
by Frisco
I have had Di2 shift issues with the clutch engaged also. In my case it won’t shift out of the smallest 3-4 cogs
spdntrxi
by spdntrxi
Frisco wrote:
Wed Mar 06, 2019 4:47 pm
yes this is pretty much what is happening to me.... this was not the case with my other cassette though? No other changes.. I know my chain is on the long side with the 11-34.
bm0p700f
by bm0p700f
I like my leonardi 9-36T cassette. shifting has been excellent over than last few hundred km. Moving it over to an new MTB.
Frisco
by Frisco
I checked torque on the clutch and it measured 3.5Nm. I didn’t try to adjust it yet. I also noticed my battery drained the day it wouldn’t shift. so at this point I assume I didn’t setup something correctly and will double check the derailleur alignment and my chain length this weekend.
spdntrxi
by spdntrxi
I might go 1x very soon... maybe get a e13 race cassette (9-46) with a 42 or 44t upfront and get an XTR M9050 RD... and call it done. I have so many overlapping gear ratios with 2x and the large cassettes I have, I basically have 14-15 speeds which is not much more then 11.
markdjr
by markdjr
spdntrxi wrote:
Wed Mar 06, 2019 4:03 am
Im running the RX with a 11-46 cassette and a Wolftooth Roadlink and it shifts through, I would be surprised if its an issue with the clutch or di2, maybe a problem isolated to your derailleur? I was using the 11-40 cassette without the Wolftooth and was shifting fine as well. Personally, I'd try to get your derailleur fixed before going 1x, everytime I ride my 1x bike I'm left feeling like I wish I had a double up front, unless its a cross race.
MichaelB
by MichaelB
Well, I've ended up sourcing a XG-1199 10-42 cassette for a bargain price as well as a 46T front chainring (and change to 36T inner), so looking fwd to trying the new combo .
New wheels are finally in Adelaide (bloody Ebay and their GSP ....) so looking fwd to a very different bike !!
Marin
by Marin
You really need 2x with a 10-42?
ND4SPD
by ND4SPD
I think Recon Aluminum is the lightest, their aluminium cassete 11-36 is 150g.
Next, Recon Titanium 11-36 is 210g.
Sram Red, or XG-1190 11-32 is 196g
Shimano Dura-Ace 11-30 is 211g.
Marin wrote:
Wed Jan 23, 2019 3:26 pm
jemima wrote:
Wed Jan 23, 2019 12:11 pm
How about those Recon/Oarsam cassettes?
Now sure how light their 11sp 11-36 options are.
Do they have 11-36? Do you have a link? :shock:
Edit: Found them on the Recon site, Aluminum or Ti only, no steel.
Ti 11-36 listed as 215g, 250$.
They have Cr-Mo cassettes:
http://www.recon-harry.com.tw/products/1/1
spdntrxi
by spdntrxi
Marin wrote:
Fri Mar 15, 2019 9:21 am
when you need top end and low honestly it can be useful. As my gravel bike is my only road bike for now, I dont want to lose the top end and I need a very low gear for some of the areas around me. 25% sustained in gravel is hike-a-bike territory. Maybe an E13 TRS 9-46 is the solution :noidea: I will try it.
MichaelB
by MichaelB
2 main reasons.
Still have to ride on the road to get to my dirt tracks.
Secondly, bike is setup already as a 2x, so why not keep it.
Also, the new wheels I got have XD driver, so giving it a go with the 10-42. If it turns out no good, will go to the Shimano hub driver and 11-34 cassette.
Also do some routes with steep climbs, so want to try a much lower gear
ooo
by ooo
sub $90 range:
11-36T: 11-13-15-17-19-21-23-25-28-32-36, about 235g (advertised)
viewtopic.php?f=3&t=156139
