How short a stem can you get away with on a gravel bike?
Shrike
by Shrike
I may need to get something 50mm to make the missus' bike fit (Cannondale Topstone), is that acceptable on these sorts of bikes?
Zakalwe
by Zakalwe
I’d expect the steering to be pretty unsettling on a typical ~72d gravel head tube. What about shorter reach bars to help get the fit with a longer stem?
Shrike
by Shrike
Bars have a 70mm reach already. Hard to find shorter, but I am looking..
blaugrana
by blaugrana
Zakalwe wrote:
Sat Jan 19, 2019 5:02 pm
I don't see how that would make any difference. What makes short stem unsettling is the position of the hands relative to the steering axis. If you achieve the same position with a longer stem and a shorter reach bars, the handling will be the same (assuming similar stiffness and other variables).
Zakalwe
by Zakalwe
Yes, it was in case the bars weren’t already short reach, and was mentioning it separately as another adjustment tool
CippoForLife
by CippoForLife
Most gravel bikes have slacker head angles (70-71.5 degrees) which allow for the use of shorter stems.
Because of the inherent stability of those geometries, short stems do not impact handling all that much.
BUT, on a 72 degree head angle, not so much :(
In other words I think I agree with Zakalwe.
Zakalwe
by Zakalwe
Looks like the Topstone has a 71 degree HTA in size S (that’s what I think the other thread you posted in mentioned) so maybe it’ll be ok. It’s still relatively steep compared to the DH bikes you normally see those short stems on, coming in the mid-60s normally
MikeD
by MikeD
Stem length is a fit issue. Get the length that fits. I've heard of the tiller effect from very long stems, but short stems shouldn't be an issue.
spdntrxi
by spdntrxi
from my experience.... you are going to want shorter for offroad. I was on a 120 initially kinda on a road bike fit and went with a 100mm redshift suspension stem. I did a short section of rain gutted damp -20% action yesterday that had me wishing for a dropper.
romanmoser
by romanmoser
buy a bike that fit
fa63
by fa63
The HTA is 70 degrees on size XS, and 71 on size S. I think a 50mm stem will be fine. It will feel different at first, but I am sure she will get used to it quickly.
frogtape777
by frogtape777
Its like going from a 1000 DPI gaming mouse, to a 3000 DPI gaming mouse, lots less input required to turn and react, but you easily get used to this after 2-3 rides and adapt your steering style to suit.
silvalis
by silvalis
I've never adapted quickly to high dpi mice :)
What about wide flared gravel bars to compensate for the short stem? Will slow steering back down a touch.
Chasse patate
mattyNor
by mattyNor
It all depends on Geo but unless things are really sketchy you'll adapt between bikes after a couple km. Between my bikes I have as long as 130mm and as short as 80mm stems and going from my raciest bike to the gravel bike is a jump but it feels normal after a short while. Flaired bars are pretty polarizing I'm a massive fan but some of my riding buddies hate them, same can be said about oval rings (I'm also a fan of those). Image
Sent from my Pixel 2 using Tapatalk
TheRich
by TheRich
silvalis wrote:
Mon Jan 21, 2019 12:14 am
Only when you're actually in the drops.
Where your hands are is what's important, gripping the tops on wide bars isn't going to do much.
