Sugestion for Cassette Sprocket
- Contact:
Guys, any recommendation on cassette option for my Lynskey pro cross build?
I'm currently thinking about using Deore XT 11-46, Sun Race CSMX80 11-50, or ZTTO cnc 11-50 .
does somebody here has a long term use of those cassette i've mention above? Since i will be using it for climbing mix terrain up to 25% i need bigger cogs and a good cassette.
Front Chainring will be using 38T Sworks MTN Crankset. RD use Ultegra R8000 long cage + Nautilus hanger.
thank you
Sent from my Redmi Note 5 using Tapatalk
thank you
Get an XD freehub and use a 10-46 XX1 cassette.
- Contact:
hard to get the xd body freehub for stan's locally. Choices for me now are only cassettes that suit for shimano freehub bodyMarin wrote:Get an XD freehub and use a 10-46 XX1 cassette.
- Contact:
bike build with 38T/11-40. but i still considering 11-50 sun race or 11-46 xt
- Contact:
nice info. i use ultegra r8000 rd + nautilus rd hanger. that should help for 46 or 50 cassette gear end.markdjr wrote:I'm running a 50/34 11-45 on my Lynskey ProCross with the Wolftooth. I was able to run the 11-45 XTR cassette without the wolftooth with the di2 rx derailleur.
- Contact:
okay then. thank you. as soon as i have the cassette on i'll give update. .markdjr wrote:Yeah you'll be all good up to 50. If you don't mind the steps between gears on the 1x, I say go as big as you want. I have never finished a ride thinking I had too much gearing, even if I didn't use it.
- Contact:
Finally intalled 11-50 sunrace cassette. I'm a bit umpleased by the Ultegra RD look when paired with this mega range cassette especially when the RD on 11T cog.
- Contact:
yes looks too far back it is. I've tried different types RD hanger but only this Nautilus RD hanger works well but still need the hanger lowered the RD not put the RD position back. I'm thinking about machining the hanger with stopper design that could lowered the RD and move it little forward.Bcoxa wrote:RD position looks off to me. Too far back. Not tried a 50 but my RD guide cog when I'm the 42 is forward of the centre of the cassette.
- Contact:
yaay... . problem solved.
What does it look like in the 11t with the new hanger? I don't see a pic of that. I see why you were concerned about the old one. It only gave you about 3 or 4 teeth of engagement.alibudia1712 wrote: ↑Tue May 21, 2019 10:03 amyaay... . problem solved.
- Contact:
look like that. 116 link chainTheKaiser wrote:What does it look like in the 11t with the new hanger? I don't see a pic of that. I see why you were concerned about the old one. It only gave you about 3 or 4 teeth of engagement.alibudia1712 wrote: ↑Tue May 21, 2019 10:03 amyaay... . problem solved.
Shifting on small cogs will be slow. Shifting 11-13-15 may even skip 1 cog and it will be very annoying. RD-6800/5800-GS should be better for 1x wide range, because it have offset pulley and cage axles (average pulley to cog distance will be smaller). RD-8000 is more optimized for 2x
