Challenge Strada Bianca TLR Reviews
At least as durable as a GP5K S TR. Less grip. Absorbs more sealant over time. Better than the GK Slick in almost every metric except price and ease of installation.
You can order it in the US from any Trek dealer, most other LBS, BikeTiresDirect, etc. Not a hard tire to get a hold of. Buying a bunch from Bike24 or some other EU shop is cheaper though.
Thanks for the insight.TobinHatesYou wrote: ↑Tue Feb 15, 2022 6:51 am
Have just discovered that they go really well on rollers. Hoping that translates into good road speed.
cycling / nature / music
Update on this: even though the Strada Biancas go really well on rollers, they're not suitable. They left a black rubbery deposit on the actual rollers. I think the rubber compound is too soft for this use.
On the other hand, absolutely loving them out on the road, so fast and comfortable. Maybe they won't last that long but it'll be fun while they do.
FYI- I just got some Strada's mounted. These are made in Thialand. I didn't see that detail anywhere. That means they're probably made by Vittoria (or just using their old factory setup/employees/process). Looking at BRR's measurements, they're basically the same as Corsas.
Edit: nevermind, just looked at the factory pics and they are different factories - https://www.challengetires.com/production https://cyclingtips.com/2019/04/inside- ... acilities/
Not exactly apples-to-apples, but I could no longer discern the heringbone pattern on the center of the rear tire when I was running Strada Pro HTLR in 700 x 30 (61/64 psi) on 21mm internal tubeless carbon wheels in under 1200 miles of use on mostly good road surfaces. I oberved similar wear patterns 3+ years back before I went tubeless and was riding on Vittoria's Corsa 320 TPI clinchers 700x25/28 with Challenge latex tubes, albeit at higher pressures.
- Michael
What wear are people getting on these? Between these and the Rene Herse but don't want to be shelling out £120 on a set of tyres that only lasts 2-3000km
Sorry if this has already been mentioned. I've just received a pair in 36mm. They both weigh exactly 377g on my kitchen scale, which is surprising in itself. Also surprising, they measure c.102mm bead to bead, compared to a brand new regular 40mm Gravelking measuring c.98mm. Not mounted yet.
You're best off with Orange Seal, but they will still lose more air overnight than vulcanized tires and the sealant will still evaporate quickly. Sealant lasts for ~3-4 months typically in the autumn here, but my Challenge tires were dry in 5 weeks. Still, a lovely tire if you don't mind the frequent top ups. I pump all my tubeless tires prior to riding anyway.
I'm using Hutchinson Protect'air which seems very similar to Stan's. I've logged 1300km on my Strada Biancas now and have had two rear wheel punctures, both of which sealed quickly. To be fair, one of those was the other day on proper unsurfaced off-road, a gravelly farm track. Other than that, the tyres hold air quite well.
