Gravel bikes/frames with full internal cable routing
NickJHP
by NickJHP
Open frames (U.P. and U.P.P.E.R.) have full internal cable routing, but they're not on the cheap side.
Zakalwe
by Zakalwe
mr4fox wrote:
Mon Feb 04, 2019 8:42 pm
my new ICAN GRA 02 has full internal cable routing and so far im well impressed with the quality. only had a couple weeks though so have only ridden it on Snow and asphalt but so far im loving it!!
I got one of these a few weeks ago also, I too am pretty impressed by the quality of the manufacturing as well as the ride
jemima
by jemima
Planet-X (UK) Holdsworth Mystique (frameset, or a couple of completes). Looks like the U.S. new Blue Hogback is using the same frame.
Ribble CGR SL (frameset or complete). A couple of hundred grams lighter frameset than the above.
Curve Grovel ti.
fourfa
by fourfa
DJT21 wrote:
Sun Dec 16, 2018 12:52 pm
Zakalwe wrote:
Sun Dec 16, 2018 11:27 am
There’s a few people here with one, seem to be well received. Done a bit of research, there’s a few threads on various forums. I’m in the process of ordering one at the moment, it’s all been straightforward so far
viewtopic.php?f=4&t=143318&start=30
There’s a few posts in that thread. I was also looking at a Workswell gravel frame, but the fork was only 15mm axles I think for the one I liked. Manufacturing quality of the Carbonda is allegedly better than most other open mould Chinese frames as well. We’ll see how it turns out, painted and with seatpost, HS and axles works out to 500 quid
Thanks for the info, much appreciated. With regards to the internal routing, do you know if it uses full length outers, or are the outers only between the shifters & mechs and the cable entry/exit ports i.e. exposed inners inside the frame?
Awfully late, but having just finished a build I figured I might as well chime in. It's full housing F & R from shifter to derailleur.
Thanos
by Thanos
Mason Bokeh and BokehTi
Sent from my BLA-L09 using Tapatalk
DJT21
by DJT21
The ICAN looks pretty good, sadly the largest size is too small! I still haven't bought anything yet, ideally I'd like one of those Orbea Terras, finding one secondhand is the problem.
lisu
by lisu
Fuji Jari:
petert123
by petert123
Thanos wrote:
Sun Feb 10, 2019 12:17 am
Not quite - the rear hose exits before the BB - I looked at these frames myself, but the Mason's don't use something like a T47 BB that would facilitate this.
petert123
by petert123
NickJHP wrote:
Tue Feb 05, 2019 3:38 am
Yep. they are on my list, the UPPER in preference because it's not painted and the weight of course.
Zakalwe
by Zakalwe
DJT21 wrote:
Sun Feb 10, 2019 12:25 pm
ICAN AC388 comes in a larger size, but the tyre clearance is a little less. I think it’ll take 38mm or so
emorydptt
by emorydptt
Colnago Prestige
be Khoi, be Khang!
-2014 Cipollini Bond EPS | 2017 enigma echo SR11 | 2011 Time RXR ULTeam SR11 | 2010 Colnago EPS SR11 | 2013 Colnago C59 SR-EPS | 2011 Colnago Prestige Di2 | 2013 Specialized Shiv TT SWorks SR11
thk
by thk
The Giant Revolt Advanced also has internal cable routing.
