Gravel bikes/frames with full internal cable routing
DJT21
by DJT21
I'm not after something niche/custom/expensive, just something off the shelf.
The Trek Checkpoint is close, but the cables are exposed along the chainstays.
Focus bikes appear to have full internal routing, but they don't make a Gravel bike.
Zakalwe
by Zakalwe
Carbonda CFR505 is fully internal I think
cerro
by cerro
Specialized Diverge. The carbon version got them integrated all the way, the alu versions outside the chainstays.
/jonas l
Beancouter
by Beancouter
My new favourite is the Basso Palta - maybe a bit on the expensive side, even frame only (but think comes with seatpost and stem). Also dedicated 1x but think it is a great looking bike.
AlphaDogCycling
by AlphaDogCycling
Parlee Chebacco
Haute Route Ambassador- ask me how to have one of the greatest experiences of your life
spdntrxi
by spdntrxi
AlphaDogCycling wrote:
Sun Dec 16, 2018 1:04 am
Parlee Chebacco
I'll add Parlee XD
NickJHP
by NickJHP
Kinesis Tripster ATR has internal cable routing...
DJT21
by DJT21
Thanks for the ideas, most are too expensive unfortunately.
Zakalwe wrote:
Sat Dec 15, 2018 5:45 pm
This looks promising though; do have you any personal experience with this frame?
The geometry is close to what I want, as this'll also be a bike used for road duties.
Zakalwe
by Zakalwe
There’s a few people here with one, seem to be well received. Done a bit of research, there’s a few threads on various forums. I’m in the process of ordering one at the moment, it’s all been straightforward so far
https://weightweenies.starbike.com/foru ... 8&start=30
There’s a few posts in that thread. I was also looking at a Workswell gravel frame, but the fork was only 15mm axles I think for the one I liked. Manufacturing quality of the Carbonda is allegedly better than most other open mould Chinese frames as well. We’ll see how it turns out, painted and with seatpost, HS and axles works out to 500 quid
DJT21
by DJT21
Zakalwe wrote:
Sun Dec 16, 2018 11:27 am
Thanks for the info, much appreciated. With regards to the internal routing, do you know if it uses full length outers, or are the outers only between the shifters & mechs and the cable entry/exit ports i.e. exposed inners inside the frame?
Zakalwe
by Zakalwe
From what I can glean from online pictures, the brake housings are full length for obvious reasons, and gear cables are housed to the entry points only. If you do a google image search you can see the cable guides in place, with large hose for the brake housing and thin hose for gear cables.
I’m no expert though, I’ve not yet handled one of these. There are users here who own one though
dang3rtown
by dang3rtown
The Orbea Terra has good clearance, a very clean look and full, internal routing. The M31d is a complete 1X build at $2999
DJT21
by DJT21
dang3rtown wrote:
Mon Dec 17, 2018 11:30 pm
Really like that, although sadly it's too expensive and I can't imagine one coming up used any time soon.
onemanpeloton
by onemanpeloton
Giant TCX advanced
2017 Giant TCR Disc
2015 Giant TCX
2016 Cube Stereo 140
mr4fox
by mr4fox
my new ICAN GRA 02 has full internal cable routing and so far im well impressed with the quality. only had a couple weeks though so have only ridden it on Snow and asphalt but so far im loving it!!
