SuperX size advice
PerOI
by PerOI
Hi guys,
Im in correspondance with a seller, regarding his Cannondale SuperX Di2 2018 size 56.
Hi's 190 cm / 6 feet 2 inch, 92 cm / 36 inch inseam.
I'm 193 cm / 6 feet 3 inch, 92 cm / 36 inch inseam.
He informed me that it should fit, but after searching a bit my understanding is, that it´s too small for him and therefore also me, and a 58 or even 60 would be appropriate.
Anyboy with experiance able to confirm whether or not I'm correct?
Thanks
Marin
by Marin
He's wrong, you're right - defintely too small.
Even a 58 would be on the small side for you, depending on how aggressive your position is.
jever98
by jever98
I am 200cm and ride a 61, but these recommendations are always risky.
No longer in the industry
Bigger Gear
by Bigger Gear
I am 183cm/6ft with 87cm inseam and quickly scanning the geometry charts I would choose a 56 so for sure it is too small for you. You'll need to run your existing fit numbers to determine if you need the 58 or 61, but definitely not the 56.
Hoven
by Hoven
I’m 186cm with long legs (around 90-90,5cm inseam) and ride a 58cm in both Superx and Supersix. Saddle height around 82,5cm.
jever98
by jever98
Those are not long legs :-D. I'm 2m with 99cm inseam and 88cm saddle height
Hoven
by Hoven
Wrong of me, my correct lenght is 94cm messurred this morning :beerchug:
