toeing in canti brake pads?
Catagory6
by Catagory6
does it matter which end gets toed in?
whether it is the end towards the front, or towards the rear?
/ ^ \ = pad - direction of wheel - pad
or
and how much toe angle is too much toe angle?
mattr
by mattr
Catagory6 wrote:
Fri Sep 14, 2018 7:04 am
one stops squeal/judder, the other makes it worse. So yes.
/ ^ \ = pad - direction of wheel - pad.
a mm should do it. Unless you have flexy brakes/forks
ALAN Carbon+
by ALAN Carbon+
Catagory6 wrote:does it matter which end gets toed in?
or
Put a business card between the rear third of the pad and the rim, then pull on the brakes and tighten them down. That should give you enough toe in.
Sent from my ONEPLUS A5000 using Tapatalk
