Suggestions needed for new Gravel/Endurance Bike
mesomaxl
by mesomaxl
and there comes the new Warbird
https://salsacycles.com/bikes/warbird/2 ... gra_di2700
Nice thing, but BB86 puts me off though…
wheelzqc
by wheelzqc
What's wrong with BB86 or BB90 ?
mesomaxl
by mesomaxl
to me the entire construction is odd. BB90 for instance is something which is a fault by design, as the concept isn`t able to take the repeating load on a crank-shaft without doing damage to the frame. the tolerances needed for this concept to work are so minimal that you end up having mis-fit and therefore cause wear in your frames bottom bracket. The fact that the "fix" from Trek is to sell oversized bearings which you have to hammer then into your frame in order to compensate the wear, seems rather odd. especially given the premium they charge you for their products.
With BB86 its a similar story.. but at least you can buy conversions, similar like Praxis is offering for PF30.
The concept of two cups (or bearings) that get pressed into a plastic material (which carbon is in the end) without any parallel or horizontal misalignment due to manufacturing deviations is odd to me. Asking around, PF30 is often mentioned as the preferrable application, if there is no way getting around a pressed bracket. I`m hoping for T47 in the future.. but for now, there seems often no way around it.
EDIT: Maybe check for Hambini on Youtube - that guy seems to be qualified to judge on these things :)
LeDuke
by LeDuke
Rodeo Labs. Their Trail Donkey is a great bike.
www.rodeo-labs.com/td2/
mesomaxl
by mesomaxl
yeah, i'm in contact with them - but as it seems i have absolutely no possibility to give it a test-ride. Its a bit strange to me to put down 2500$ for something i have never seen or even ridden :-/
jemima
by jemima
Complete bike: Planet-X Holdsworth Mystique ??
philipBer
by philipBer
mesomaxl wrote:
Sun Sep 16, 2018 8:42 am
So.. "back to the drawing board" - the VPace seems to especially fit my geometry-needs (long legs, more comfy position).
Waiting for a reply regarding Di2 / 650b and frame finish - on the other hand… Ravensburg is less than 2 hours from Zürich.
We'll see :)
Have meet the guy behind Vpace several times, nice chap! A Di2 only frame is possible and has a lead time of ~10 weeks. That's at least what he told me... If you are around the corner, visit Vpace and have a chat with Soeren. You most likey will get decent coffee too... ;)
My favourite solution at the moment is the Vpace Frame with custom paint...
philipBer
by philipBer
mesomaxl wrote:
Mon Sep 17, 2018 8:44 pm
Great frame but in my opinion boring paint....
mesomaxl
by mesomaxl
since i`m getting no replies from VPace, my eyes start wandering off again towards Carbonda. Still uncertain whether it's worth the risk. But custom paint carbon for sub 800 sounds promising.
philipBer
by philipBer
mesomaxl wrote:
Thu Sep 20, 2018 4:05 pm
Did you try to call him? That's maybe the quicker way to get a response. Its a two man show after all... ;)
twoangstroms
by twoangstroms
A lot of good suggestions!
I've been loving my Ibis Hakka MX (and saw one parked locally but with 650 wheels, and it looked great, too). It has a T47 BB, so when I went to change the crankset, I had to get a new BB, splurged on a Chris King. If the sizing works for you, it's hard to say that'd be a wrong bike.
Powerful Pete
Location: Lima, Peru and the Washington DC area - it's complicated.
by Powerful Pete
Does the Ibis Hakka have flat mount discs?
Supercommuter: Jamis Renegade...
Oldie but goodie: De Rosa Professional Slx, Campagnolo C-Record...
twoangstroms
by twoangstroms
On the rear, yes. The model year I have, the Enve fork that came with it has post mount. Honestly, I haven't noticed any difference in performance of front versus rear brakes. If you're really set on flat mount front and rear, I suppose you could replace the stock fork.
mesomaxl
by mesomaxl
sadly the Hakka doesnt match my geometry preferences with rather long legs.. or put differently.. i'm not flexible enough in the spine to take such a racy position. Especially not for longer distances
twoangstroms
by twoangstroms
Oh, that's funny about the fit. I have a long torso and proportionally long femurs, so I need the 53 for the top tube and seat angle being slack enough, so it feels a bit on the large side and I've had to slam the stem. But the shorter stem that allows gives me great handling both uphill and downhill. The thing tracks really well, feels super smooth, and is totally responsive.
