tomh79
by tomh79 on Thu Apr 16, 2020 3:14 pm
leonlikestrees wrote: ↑Thu Apr 16, 2020 1:27 pm
put a ritchey wcs stem and pro plt bar on, ultegra 6800 cranks (+stages power) with superstar raptor 40t ring,
nice!! reminds me: have to replace the bolts as well
Question: How does that Ultegra crank work for you? Since it's a road crank with a narrower (43.5?) chainline? Did you notice a difference? Thinking of putting an Ultegra crank as well, but 2x.
g32ecs
by g32ecs on Fri Apr 17, 2020 4:17 pm
Has anyone tried using it on the road with proper road wheels/tires? I guess anything 28c and below these days.
Slowly trying to convince myself, but not totally convinced.
tomh79
by tomh79 on Fri Apr 17, 2020 6:33 pm
g32ecs wrote: ↑Fri Apr 17, 2020 4:17 pm
Running gp5000 32mm tubeless (topstone 105 aluminium) - constantly beating my PRs (2014 carbon Synapse Ultegra)...not scientific in any way, but my Synapse is 2kg less weight...
choiboi
by choiboi on Fri Apr 17, 2020 9:13 pm
tomh79 wrote:choiboi wrote: ↑Fri Apr 17, 2020 2:20 am
I run DA9000 2x on mine with no issues
nice - are you running 50/34 - 11-34?
Yep! Just the stock 105, 11-34.
Chain is abit short , but I can deal with that when the original chain wears out!
No reason for picking the DA other than this used one I found for a bargain had a stages
Sent from my HD1900 using Tapatalk
David
[b]'10 CANNONDALE CAAD10
cerro
by cerro on Fri Apr 17, 2020 9:29 pm
Yes, used my Topstone carbon on road a bit. 28mm Specialized Hell of the north tubular tires on Ambrosio Crono F20 rims
And tried Pirelli P-Zero 28mm on the stock rims (105 model) but the wheels felt heavy so not as fun as with my 1515g tubular wheels. Works great for road if not riding superfast I would say.
g32ecs
by g32ecs on Sat Apr 18, 2020 12:03 am
Would be great if I can kick some ass or podium on it in a local crit
Having enough power is another story
Onto fantasizing about this more. I think my Fat Bike will need a new home soon
markgoldstein
by markgoldstein on Tue Apr 21, 2020 3:44 pm
Hi all,
Quick question on Topstone AL sizing...
I ride a 54cm Supersix (2018, rim-brake) with stack/reach of 551/387.
This seems to be equivalent to a Small Topstone in terms of stack height, with a stack/reach of 549/377, but more to the Medium in terms of reach, with stack/reach of 579/385.
I'm guessing the fork length/axle-crown is longer on the Topstone to compensate for the difference in head tube length? (139 vs 118mm on the Small frame)
Does anyone here ride a 54cm Supersix and a Topstone? And if so, which size Topstone?
I'm kind of leaning towards the small Topstone, with the same stack and shorter reach which would accomodate the longer disc brake shifters...
cerro
by cerro on Tue Apr 21, 2020 9:08 pm
How do you sit with spacers, stem lengths and saddleheight on your SuperSIX?
Reach is easy to fix with a longer stem, too high stack can be harder and doesn't look so good with a short very negative stem.
fourfa
by fourfa on Tue Apr 21, 2020 11:43 pm
If anyone knows of an off-the-shelf full frame bag that fits a size SM aluminum Topstone, please let me know... Not so easy to pop 'round all the local shops currently
leonlikestrees
by leonlikestrees on Thu Apr 23, 2020 2:03 pm
tomh79 wrote: ↑Thu Apr 16, 2020 3:14 pm
No issues at all with it setup 1x, all working really nicely.
leonlikestrees
by leonlikestrees on Mon Apr 27, 2020 7:42 am
Tyre talk....I built mine up with gravelking SK 35mm I already had (bought for last year's three peaks - not grippy enough fyi!). They are great for mixed conditions, but when I go off road I still feel like I'm on a cross bike.
My franken-gravel bike was a 26" MTB I'd managed to squeeze some 650bx 42 tyres into, and I loved the float and cush from those.
I'm certain the 650x42s will be too low. I can't try at the moment as I need to convert to thru axle. Given I have both 650 and 700 wheels hanging around, I'm unsure what to go for.
Anyone run both and have any feedback? E.g. 650x47 and 700x42? Gut feel is if I was happy with 650x42 on my old bike, 700x42 will feel great but good to hear what people think.
I'll probably go with something with a light tread, like the SK. I don't need full on knobblies for what I ride, and the main use of the bike is to substitute road miles (commute or training) with more interesting mixed rides, so I still want it to feel like a road bike on tarmac
