Lightest Cyclocross Frame Set?
sib
by sib
The Ridley X Night SL is said to come in at 860grams for a painted size 52 (535mm top tube) frame, with a 480gram fork:
https://ridleybikes-ridley2.netdna-ssl. ... 8_V2.1.pdf
The Scott Addict CX 10 is 890 grams frame (size unknown) + 360 grams fork:
http://www.scott-japan.com/sites/defaul ... T%20CX.pdf
The Canyon Inflite SLX is 940 grams for an M frame (similar to L in other brands?) and 360 grams fork:
https://www.canyon.com/en-jp/road/infli ... f-slx.html
The Focus Mares is 920 grams for a 56cm frame + 420 grams fork:
https://road.cc/content/news/110523-foc ... -bolt-thru
Felt F FRDX is 850 grams for the frame + 400 grams fork (thanks to AndreLM):
https://www.cxmagazine.com/felt-2016-ca ... gle-ring/6
Specialized Crux is 900 grams for a 56cm frame + fork weight unknown:
https://www.specializedconceptstore.co. ... 2018-crux/
Anything lighter?
What other options am I missing at a similar weight?
It would be nice to have a thread with as many weights as possible.
prebsy
by prebsy
I can't contribute much as my RXC pro is a hog but in my experience I'd trust Scott to get closest to their claimed weight. CX weights balloon pretty quickly but that's from the equipment choices not the 100-200g in the frame weight.
Strava
Current Stable:
Specialized Allez Sprint Disc
Cervelo Aspero
Scott Spark 910 Contessa
liam7020
by liam7020
I had a Ridley cross frame a few years ago - the published weight was CONSIDERABLY lighter than the actual. Also owned a couple of Focus Mares frames, both of which were very close to the published weight.
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
AndreLM
by AndreLM
Felt F FRDx should close to Scott weight
northwestern
by northwestern
2018 Ridely X-Night Sl in size 56 actual weight is 1760 gr
https://www.competitivecyclist.com/ridl ... QxMDAxNTg=
Multebear
by Multebear
prebsy wrote:
Thu Jul 26, 2018 2:46 pm
It's also my understanding, that this is one of the lightest ones.
sib
by sib
A couple more framesets added (thanks AndreLM!).
menkar
by menkar
Cannondale SuperX 2017/2018 frame is "under?" 1000g and fork 390g.
iflyadesk
by iflyadesk
FWIW, I bought a Specialized Crux that was steeply discounted just for its frameset because the Crux was supposedly "so much lighter" than my Santa Cruz. However, after taking home the new Crux, I was horrified by the weight. So I started taking it apart (as much as I dared on a bike I was pretty sure I would now return) and weighing everything. What was left, I estimated based on published weights (which I know is dangerous). Still... it was 485g heavier than expected. Something doesn't add up.
Specialized Santa Cruz
Wheelset
Wheels
Tires
Tubes
Cassette
Rotors
Total Wheelset 3,730 2,420
Seatpost + Saddle 620 318
Handlebars 300* 170
Handlebar tape 80* 80
Brake levers, cables, fluid, calipers 886* 701
Front Derailleur 95* 0
Rear Derailleur 225* 272
Chain 257* 245
Crankset 800* 472
BB 138* 120
Axles 69 74
Stem 135* 135
Power Meter 0 65
Frame 900* 1,050
Fork 400* 575
Headset 50* 50
Hardware 30* 30
Expected total 8,715 6,777
Unexplained 485 20
Actual Weight 9,200 6,797
*estimates
