Seeking 27.5 (650b) rim brake wheelset
mpulsiv
by mpulsiv
I know that my choices are limited when it comes to rim brake wheels. My goal is to mount Compass 650Bx42 Babyshoe Pass on my endurance bike with Velo Orange Grand Cru long-reach brakes. I'm looking for something on a budget, like Velocity CliffHanger http://store.velocityusa.com/p/cliffhan ... nger?pp=12
What else is out there?
When it comes to rim profile, I'd like at least ~30mm wide.
Marin
by Marin
* You won't reach around a 42mm tire with mid-reach brakes - you need true long reach, which means Tektro r559, or something cheap from Dia Compe or off an old BMX.
* If you want 25mm internal, rim choice is severely limited. I'm running 42s and 48s without problems on Pacenti Brevets with 19mm internal width. At these widths, you can also use A23s and HED Belgiums.
* What frame and fork do you have to have so much tire clearance? Very unusual.
mpulsiv
by mpulsiv
Marin wrote:
Thu Jul 26, 2018 8:31 am
Sorry, the Velo Orange Grand Cru is long reach (47-57mm) and the Tektro R559 are extra long (55-73mm). Looks like 650b Babyshoe with Tektro R559 will work :beerchug:
$450 is actually not bad for Pacenti Brevet wheels https://pacenticycledesign.com/collecti ... ed-shimano
How does Tektro R559 perform? At that height, I'd imagine they are flexy.
Source: www.reddit.com/r/Bikeporn/comments/5k8e ... ty_mr_pink
Marin
by Marin
Do you have a Mr. Pink? Nice!
R559s are ok, not as flexy as you'd think. Throw the pads away and fit R55C4 or TRP and you can lift the rear wheel from the hoods.
My Heretic with r559, Brevet rims and Gravelking SK 48s:
mpulsiv
by mpulsiv
Marin wrote:
Thu Jul 26, 2018 10:40 am
Yes, indeed.
We must have the same Whisky No. 7 fork. Looks like it will clear ~47mm tire? https://bikerumor.com/2017/01/17/whisky ... -road-plus. Whoa, that means Compass 48mm Switchback could clear the fork. I doubt that it will clear in the rear due to 415mm chainstays. How long are the chainstays on your Heretic?
I was never impressed with R55C4 (Dura Ace pads). I'm runnning Kool-Stop salmon pads on all bikes, rain or shine.
If I'm not mistaken, you mentioned that knobby tires don't serve much purpose on gravel. I don't have the source handy but I belive that Jan Heine backup this statement.
When it comes to 650 conversation, it's a bit of hassle to switch brakes from Tektro R559 (e.g. too long to work on 700c rim) to VO Grand Cru, everytime I want to ride gravel.
This is where the versatality of disc frames really shine.
Marin
by Marin
Yes, I didn't ride the Gravelking SKs much. Even if I rode a very gravel-focused event like Torino-Nice I'd probably stay on slicks, 42 or 47mm.
My go-to setup is 42mm Pari-Motos tubeless, they do everything well and are *very* fast on tarmac. This is a setup you can run for road & gravel.
Yes, same Whisky fork, will clear 48mm easily. I designed the Heretic to have 47mm clearance in the rear too, with 420mm stays. Check your chainstay clearance at 315mm from the dropouts, that minus about 2x5mm is the tire width you can run.
mpulsiv
by mpulsiv
Marin wrote:
Fri Jul 27, 2018 7:39 am
Hmmm...are you sure that it’s 315mm? I measured 355mm from the fender mount to dropouts. It’s quite narrow by the fender mount, ~32mm.
650b topic aside, is it safe to run 28mm Vitoria latex tube in 35mm Bon Jon? I know that latex expand much more than bytul but 35mm tire is a lot of volume.
Marin
by Marin
Widest point of the tire is @ 315mm IIRC, radius to the tread is 338 for a 47mm tire.
I ran exactly those tubes in the Bon Jons, but they are now set up tubeless.
ultimobici
by ultimobici
The ultimate do-it-all bike???
https://r.tapatalk.com/shareLink?share_ ... are_type=t
mpulsiv
by mpulsiv
ultimobici wrote:
Fri Jul 27, 2018 6:15 pm
Is "The ultimate do-it-all bike" thread somehow relevant to "650b rim brake wheelset" thread? :noidea:
FreaK
by FreaK
I think it's the mention in the last post. But it barely qualifies as information: "Oh, and I had 650b carbon rim brake rims made which built into a 1070g wheelset. Didn't test them yet though,..." - Marin
He doesn't say anything more.
I know one option is the Cherchio Ghisallo with the internal carbon reinforcement, but i suspect the braking performance might be a bit down relative to a modern carbon brake track treatment. Then again, those are on the +500g side of things anyway.
it's actually possible to come to the conclusion even before realising it makes no sense at all
tymon_tm
Marin
by Marin
What do you want to know? Wheels are still unridden BTW.
FreaK
by FreaK
Well, for starters, can i get a pair if I wanted to? Who made them? How much do they weigh on their own?
tymon_tm
DutchMountains
by DutchMountains
Marin wrote:
Wed Jul 25, 2018 9:50 am
Yes. There aren't many light 650b rim brake rims around, there's the A23 and the HED Belgium, and I heard that Kinlin XR31 might come in 650b later this year.
I asked Kinlin about this and they confirmed that the XR31 will be available in 650b size, both for rim brakes (XR31T) and disc brake (XR31TS). Sadly no asymmetric version :( From the datasheet they sent me: ERD 532.5mm, weight 460 gram; the same datasheet lists the 700c version as 570.5mm and 490 gram.
No response (yet) when asked about when these would be available.
mpulsiv
by mpulsiv
DutchMountains wrote:
Tue Aug 14, 2018 6:45 pm
Good to know. Looks like rim profile is not much different next to Pacenti Brevet. Both have ~19mm inner and 23-24mm outer. Weight is ~460 grams. Kinlin is twice as deep though at 31mm, where Pacenti Brevet is 15mm. If Kinlin release 24 spokes that would be the only weight savings since Pacenti Brevet is only 28 spokes.
Speaking of rim profile, doesn't Hunt use Kinlin XR31 rim? www.huntbikewheels.com/collections/road ... eep-24wide. Recently, I reached out to them asking whether 650b is in the pipeline. They said "no". Polished wheels are aesthetically pleasing.
