Largest tires on Trek Boone?
I searched and came up empty. What is the largest tire that can be fitted on a Trek Boone Disc (2016)? Tons of room in the front but the rear looks narrow at the chain stays. What have people managed on the rear? Was thinking of doing a little gravel riding.
You’ll want to find actual measured widths dependent on rim width of which they are mounted.
The max on that era of boone was a 38. I had 38s on mine when I owned it.
This.Fisherfreerider wrote: ↑Tue May 29, 2018 9:35 pmThe max on that era of boone was a 38. I had 38s on mine when I owned it.
I bought my wife a Boone 7 (cantilever) and fit some 36c tires on there (Clement/Donnely MSO Tubeless). No issues with clearance. You can probably fit a 38c, but I wouldn't go beyond that.
Emonda SLR (under construction), Madone 5, Cobia. I own a lot of Treks.
would there be increased clearance with a 650b wheel? thinking of getting one. what is the biggest tire you could fit with fenders? 35 or 38mm?
I don't think you could fit a bigger tire if using 650b wheels. The design of the chainstays open up where the tire is located and then narrow towards the rear for a bit before flairing to the dropouts.
I'm building up a 2016 trek boone and these are pics of Maxxis Rambler 40's mounted on Stans Crest(21mm inside) 29 rims. It looks so close in the photo but there is good space there. I'm very pleased with it but certainly couldn't go wider.
- Similar Topics
- Replies
- Views
- Last post
2018 Trek Boone - fast gravel set-up
by plpete » Wed Jul 18, 2018 2:23 am » in Introduce Yourself / Gallery - Please use metric weights. - 27 Replies
- 5687 Views
Last post by erolorhun
Fri Nov 30, 2018 1:13 pm
Trek Boone cx frameset 2018/19 52cm incl BB + seatmast
by rynogee » Sat Jan 19, 2019 5:15 am » in For sale - Pictures are mandatory 22-3-13 - 0 Replies
- 203 Views
Last post by rynogee
flat mount or post mount for 2016 trek boone
by jjones » Sun Mar 11, 2018 3:28 pm » in Cyclocross / Gravel / Touring - 2 Replies
- 672 Views
Last post by jfranci3
Tue Mar 13, 2018 4:22 pm
Sanity check: 2016? Synapse to 2019 Boone
by TheRich » Tue Jan 01, 2019 2:29 am » in Introduce Yourself / Gallery - Please use metric weights. - 8 Replies
- 878 Views
Last post by TheRich
Thu Feb 07, 2019 5:30 am
- 10 Replies
- 1486 Views
Last post by izza
Wed Feb 20, 2019 10:34 pm
