Starting to build up Focus Marex CX. Disc Brake Noob Help
Catagory6
by Catagory6
very preliminary stages of the build, and i'm looking at the rear disc brake cable routing.
i've got the front and rear derailleur sleeves threaded thru the down-tube ports, and around the BB cable guide.
but i cant figure out how the rear brake cable housing passes thru the bottom bracket shell, and the bottom bracket spindle
following photo is the port in the head tube for the rear brake cable housing
https://imgur.com/xb7Ha96
obviously the housing gets routed inside the down tube, but does it go through the center of the bottom bracket shell, through the 2 ports in the following 2 pictures
https://imgur.com/e1eYqCM
https://imgur.com/cpYV4b4
or does it get routed through the same ports the the shifter cables go through (sorry, blurry picture)?
https://imgur.com/YDhRe1F
sorry, i can't figure out how to post pictures. but they're in the links
Catagory6
by Catagory6
i think i might have figured it out.
there's a length of foam tubing that came with the frame set.
is this foam tubing run through the bottom bracket shell, and protect the housing from rubbing on the BB spindle?
Catagory6
by Catagory6
foam rubber running through BB shell, would go underneath bb spindle?
tell me if i'm laughably wrong.
edit: no, that would be stupid. it goes over the spindle. obviously.
https://imgur.com/oH2POBj
Catagory6
by Catagory6
are there any gaskets to seal up the space between the brake housing, and the ports in the frame?
looks like a really nice way for water and dirt to make its way inside
wannbwe43
by wannbwe43
The pictures are not shwoing full spectrum, I don't see too much
Catagory6
by Catagory6
at the risk of burying my own question inside my existing thread, instead of making a new thread about a related subject, i will tack on to an existing thread.
in my research into the world of disc brakes, i have come to the conclusion to go with CENTERLOCK hubs/rotors.
i have since discovered that there are two (2) different types of locking rings dependent on the type of axle, and frame clearance.
1. internally splined lock ring - which requires a cassette tool
2. externally splined lock ring - which requires a bottom bracket tool
for convenience- and bank account's sake i would like to be able to run the same type of lock ring on both FRONT and REAR hubs.
both run 12mm thru axle. which as far as i can tell, accommodate internally splined lock rings (cassette tool).
but i am unsure if the front hub, or the rotor itself will accommodate an internally splined lock ring.
from what i've read, the front hub requires the externally splined lock ring, and the rear hub, may or may not accommodate an externally splined lock ring, depending on frame clearance.
if what i have just written makes any sense at all, can YOU make it make sense to ME?
thanks
ms6073
by ms6073
In my experience with 12mm thru-axle, you will need the external lockrings as nobody makes a tool capable of loosening an internally splined lock ring with a 12x142 or larger rear thru-axle centerlock hub.
