Sram Force 1x Crankset and Preload Adjuster question
cassard
by cassard
I just installed my crankset Force 1x BB30 on my CK T47 bottom bracket and I have one or two questions. I followed the SRAM tech instructions.
But when I tighten the preload adjuster in the arrow direction like they say, until it stops, I still feel some friction when I turn the crankset. And if I take off just a bit of tension, it's smoother. is it normal ?
Also, the preload adjuster beeing made of plastic doesn't seem to be very sturdy or durable. Some of my friends mechanics told me it's crap and it will become loose and I should put spacers instead.
and Finally when installing, the instructions tell to tap with the mallet to slide it, but I didn't need to do it, it seems to slide fine and then I just had to screw and torque it to 54 Nm. is that normal ?
Any insights ?
moyboy
by moyboy
Tolerances are tight with some bottom brackets which would require a rubber mallet or so to help it in.
As for the pre-load, it does feel insignificant and i'm using spacers on my bike instead of it. I'm using it with a 386 BB so I had to use it without the preload.
