Canyon Grail
rainerhq
by rainerhq
Marin wrote:
Tue Apr 10, 2018 10:50 am
Someone should think about how to make rigid disc forks more compliant. And no, the solution is not called "Zertz".
:D :thumbup: :thumbup: :thumbup:
Domane
Speed Concept
"Nothing compares to the simple pleasure of a bike ride"
wheelsONfire
by wheelsONfire
I think all the gimmicks will disappear, and clever component design and good tires will stay.
They probably claim a % rate of flex in some sales propaganda.
But if you ride hard, how are you sure the fork doesn't brake.
That is, if it basically is a stiff fork!
THM did an interesting prototype with lamella construction.
Canyon had a concept road (race) bike with suspension both front and rear.
I still think it's strange we see bikes like Pinarello S-models, the new Wilier NDR and others with a rear suspension of some sort.
But virtually no gravel bikes.
Excerpt is True Grit bike with the Grit fork
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
Marin
by Marin
It's all marketing gimmicks.
Roel W
by Roel W
Canyon Grail AL coming up:
CANYON Ultimate AL 2010
CANYON Ultimate CF SL 2014
CANYON Ultimate CF SL disc 2018
Instagram @roeleur
Marin
by Marin
Have fun riding offroad with 2mm fender clearance :D
jeanjacques
by jeanjacques
Marin wrote:
Mon May 14, 2018 9:36 am
You don't understand, it's not a mudguard, it's a tire wipers.
OnTheRivet
by OnTheRivet
A larger tire run at a lower pressure does magnitudes more for comfort (without screwing up handling) than any frame/fork/stem/seatpost/handlebar gimmick, and they are relatively cheap.
Roel W
by Roel W
It's there: Grail AL https://www.canyon.com/en/road/grail/#filter1=AL
Prices seem very reasonable.
Instagram @roeleur
Westbank
by Westbank
I'm a big Canyon fan... but I'm not impress by the welds :( :(
MountainAddict
by MountainAddict
I've been waiting for the Grail AL to come out, but after seeing it (and knowing it'll take a while longer before it becomes available in the States), I think I'll go with a Topstone instead.
TuplaO
by TuplaO
Those welds are not quite on the level of 'metallic bird shIt', but the lumpiness is notable, shall we say...
Shrike
by Shrike
Rare I pop into this forum, but saw the Grail AL yesterday and am considering them for the missus and I as all rounder bikes. We don't really have much by way of gravel paths in the UK, so really want something that I can adapt from road winter training to cross basically. I'd be looking to stick some cheapo power meter on mine and use it for ultras or multi-day stuff myself too. Too slow for that?
What sort of limitations would I be facing. The price and style/colours makes it a very tempting proposition, but without experience in anything aside from road cycling I'm weary to jump in.
Marin
by Marin
Shrike wrote:
Fri Nov 09, 2018 10:23 am
In my view, a bike is to the largest extent defined by rider position, tires and gearing. If you can adapt these three to your needs, you won't have any serious limitations.
Weight - 1kg will cost you about 1.3 seconds on an 8% climb with 100m of elevation gain, and it will cost you nothing on the flat.
I ride an "allroad" bike for basically everything now, from team time trials to MTB-route rides, I just swap wheels from 700x24mm to 650bx42 - and a few sizes in between just for fun :D
Shrike
by Shrike
It makes a lot of sense when you lay it out like that. I've also toyed with the idea of ditching the carbon road bike and just getting a posh all round bike to do it all. Flirted with the Open Up and Curve which I both have a thing for.
Just finished my first TT build, so maybe TT bike and all round bike would be perfect. TT for raw speed and all rounder for everything else. :)
Need to think it through...
Seth
by Seth
I'm just entering into the world of gravel grinding and I am intrigued by the Canyon Grail. I want the option to put an aerobar on for longer events or for touring. With the front end on the Grail, I can't see a way to mount an aerobar.
Is there a way?
