Your Dream Wet Weather/CX/Gravel/Commuter Bike
I got my father a Focus Paralane on sale right as the pandemic hit. It was a crazy good deal - $1500 CAD for a carbon frame with Tiagra 4700. The shop must have been kicking themselves after as it was just before the bike demand went crazy. It comes with built in fenders (removable) that look really sleek.
Honestly Tiagra 4700 is the best deal going. It's hydro and basically has the same shifting mechanism (and cable pull) as the 11 speed mechanical 105/Ultegra/Dura ace, but they just limited it to 10 speeds. I cannot tell any difference between how it shifts vs my Ultegra bike. The hoods look a bit odd with the big hydraulic bulge but for the price I could learn to love those chubby suckers.
Tiagra 4700 was the new 105 5800 with ST-RS505. There were some really good deals until march 2019. Now everything is expensive. Hopefully prices come down by the end of year or next year as most will have to spend money on mortgages, electricity and rising prices across the board.
2022 Wilier Filante SLR Dura-Ace/Ultegra Di2 12sp
2021 Cannondale Scalpel Carbon 2
Retired:
2018 S-Works Tarmac SL6 Sagan Superstar DA 9150
2016 Aeroad CF SLX UDi2
2016 CAAD12 - SRAM Red 22 - Hyper 50mm
Retired:
Here are my thoughts about bike that i'll use for commuting and touring which can include some gravel riding too
Frameset/fork should be:
- rather cheap
- be very robust so that it doesn't flex arround while loaded for touring
- have desired geometry (I like standard road racing geometry with fast handling and with STR of 1,5 on frame size 60, don't like touring and gravel geometries)
- have clearance for wide tires AND mudguards (atleast 35mm with mudguards)
- have all possible mounts (mudguards, fenders, lights, easy rider....)
- be able to accept double leg kickstand (after first touring you'll understand why)
- have external cable routing for easy maintenance (important for touring)
- have BSA/ITA bottom bracket (no place for press fit on this bike)
- have mounts for mini v-brakes (it gets alost imposible to find it these days)
Wheels should:
- have atleast 32 strong spokes (I suggest 2.3/2.0 spokes like DT Alpine) and brass nipples
- have easy servicable hubs (I prefer cup and cone bearings)
- dynamo front hub (to power up lights and usb charging)
- have strong durable rims with internal widths of at least 18-19 mm
Braking system:
- preferably mini v-brakes (disc shouldn't be you first choice - don't want to overheat hydraulics or change pads after every two descents)
- if using disc brakes I suggest cable actuated ones (mechanical like TRP spyre or hydraulic like TRP HY/RD) with atlest 180 mm rotors 2,3 mm thick (works nice with brakes designed for 1,8 mm rotors)
- use good pads and always have few spares in saddle bag as loaded bikes burn them like crazy. This is especially important for disc brakes...one long descent and you have no more pad material.
Groupset:
- Triple chainring at the front is still best whatever they tell you. Imho best combo is 50-39-26 (I modified 105-5703 series 50-39-30 to 50-39-26) with something like 12-32 cassette.
- Rest of the groupset at your own preference, but there is no place for di2/eps or such nonsences (I have built my arround Campagnolo 11 which was especially hard to combine with TRP HY/RD due to different pull ration of Campagnolo and everyone else. At the end I had to install modified actuation arm on brakes to make it compatible with Campagnolo pull)
- Have in mind to build with strong (not light) components that are easyly servicable with widely available spares
Lights:
Dynamo powered front and rear lights (for front headlight i suggest Busch and Muller IQ series of lights)
Rear rack:
- must be able to carry heavy loads and muptiple positions for bags (like Tubus Logo).
- rather cheap
Wheels should:
Braking system:
Groupset:
Lights:
Rear rack:
Which mudguards are those?freakforti wrote: ↑Mon Oct 17, 2022 8:30 pmMy Seven EvergreenSL gets the job done for years now - I just alter the tires
https://www.flickr.com/gp/freakforti/c8J3827Ac8
I recently got a giant tcx for gravelcrosswinterallroadbike and I must say it is a splendid good do-it-all bike. Great handling and riding on the roads with 28mm slicks as well as in the fields with 33 or 40-45 mm cross/gravel tires. I sure could recommend one
Verzonden vanaf mijn iPhone met Tapatalk
https://www.cyclingweekly.com/reviews/b ... y-designeduppis wrote: ↑Wed Oct 19, 2022 6:22 amWhich mudguards are those?freakforti wrote: ↑Mon Oct 17, 2022 8:30 pmMy Seven EvergreenSL gets the job done for years now - I just alter the tires
From what I can see no fender mounts so not a proper wet weather/commuter bike.
That’s trueMr.Gib wrote:From what I can see no fender mounts so not a proper wet weather/commuter bike.
Thanks, not cheap but looks good. Any rattles, do they hit the tires at all?freakforti wrote: ↑Wed Oct 19, 2022 8:19 pmhttps://www.cyclingweekly.com/reviews/b ... y-designeduppis wrote: ↑Wed Oct 19, 2022 6:22 amWhich mudguards are those?freakforti wrote: ↑Mon Oct 17, 2022 8:30 pmMy Seven EvergreenSL gets the job done for years now - I just alter the tires
