Sram etap
Jowwy
by Jowwy
Has anyone gone large with their sram etap..........i'm talking 36, 40 or 42 cassettes and single chainring upfront. If so how is it going? what changes would you make to it?
is it for road? gravel? monstercross?.............
Jowwy
by Jowwy
Chatty bunch on here lol
NickJHP
by NickJHP
SRAM only rate the eTap RD for up to 32t on the cassette (with the WiFli model). Means you might possibly eke out a 34, but probably not a 36, which is two thirds of an inch larger diameter. In the photo you show, it looks like a Wolf Tooth Roadlink has been used to drop the whole RD. I tried one of those a while ago with a Campagnolo RD to see if I could fit a larger cassette. There were two problems:
  • The shifting was crap on the smaller cogs because the top jockey pulley was too far from the cassette.
  • With short chainstays it was very difficult to drop the rear wheel out, because the whole RD had been moved forward.
SRAM 11s mechanical road shifters are completely compatible with their 10s MTB derailleurs - I have a couple of bikes using Force 22 shifters with an X9 RD and Shimano 11-40 cassette. SRAM list all the compatible components here: https://www.sram.com/sram/mountain/tech ... -actuation.
cerro
by cerro
My Specialized S-Works Diverge. 10-42 X01 cassette with a 44t Garbaruk front chainring. Sram Red eTap Wifli RD with a Wolf Tooth roadlink. Works for the gravelriding I'm doing :)
Jowwy
by Jowwy
NickJHP wrote:
Mon Feb 19, 2018 9:59 pm
Maybe the shifting was crap with the woolftooth as it's for designed for shimano and not campag.......and as you say shorter chainstays.
I've used the roadlink with the etap before in the alps with a 40t rear cassette and 46/34 front crankset and it shifted seamlessly. But then my chainstays are 440mm so not exactly short.
Also I'm talking etap here and not sram mechanical as per all the information you listed, but thanks anyway
Jowwy
by Jowwy
cerro wrote:
Mon Feb 19, 2018 10:08 pm
Looks good......would you change anything on the set-up???
grover
by grover
Nino Schurter was just spotted riding an etap rear derailleur with a clutch on his mountain bike. Means we may see an etap derailleur designed for your needs soon. Maybe just wait?
Jowwy
by Jowwy
grover wrote:Nino Schurter was just spotted riding an etap rear derailleur with a clutch on his mountain bike. Means we may see an etap derailleur designed for your needs soon. Maybe just wait?
Im not one for waiting.....and as i know its already been working without any issues with an adaptor attached thats designed for the job
No point waiting for more expensive kit that may not be compatible
Sent from my SM-G925F using Tapatalk
Jowwy
by Jowwy
It could just be happeningImage
moyboy
by moyboy
Oh boy! wonder if it will work with Red eTap shifters like how the Shimano road works with the XTR rear di2 mech
Jowwy wrote:
Fri Feb 23, 2018 9:21 am
cerro
by cerro
Jowwy: Would have liked an 11t, so 10-36 would be perfect.
Jowwy
by Jowwy
KaneChang wrote:
Sat Feb 24, 2018 6:54 pm
eTap wifil run a 36T cassette is no problem
https://youtu.be/DaJnUUYirq4
I run a 42t on mine no problem with the added woolftooth roadlink
Jowwy
by Jowwy
cerro wrote:
Sun Feb 25, 2018 7:59 pm
I'm running 42t upfront and a 11/42 cassette, works like a dream
Marin
by Marin
Even better: https://r2-bike.com/LEONARDI-RACING-Cas ... 1-speed-XD
