disc brake rotors
I'm looking for some suggestions on disc brake rotors. Mostly looking for good price to value as this is a budget build using spare parts and and lightly used ebay deals. These will be used with Shimano ST-RS685/RS805 on a Carbonda 505 that will be used for commuting/gravel/light trails. Leaning heavily toward centerlock right now.
I tried Shimano SM-RT20. cheap rotor tends to be very heavy, but works 100%.
I've been using Shimano RS805 Flatmount 160 mm / 140 mm...they've served me well...not the lightest but...erickr wrote: ↑Mon Jan 01, 2018 2:51 pmI'm looking for some suggestions on disc brake rotors. Mostly looking for good price to value as this is a budget build using spare parts and and lightly used ebay deals. These will be used with Shimano ST-RS685/RS805 on a Carbonda 505 that will be used for commuting/gravel/light trails. Leaning heavily toward centerlock right now.
just done a quick search & they're under US$50.
Building Spec Allez
Sold
Fuji SL 5.5kg viewtopic.php?f=10&t=157704
Sold -
Izalco Max Disc 6.7kg http://weightweenies.starbike.com/forum ... o+Max+disc
Sold
Sold -
I think the thread starter has already decided on calipers, hence why the request for suggestions for disc brake rotors.
- Michael
D'oh
I see what I've done...Written nonsense.
Building Spec Allez
Sold
Sold -
Sold
Sold -
Second try...erickr wrote: ↑Mon Jan 01, 2018 2:51 pmI'm looking for some suggestions on disc brake rotors. Mostly looking for good price to value as this is a budget build using spare parts and and lightly used ebay deals. These will be used with Shimano ST-RS685/RS805 on a Carbonda 505 that will be used for commuting/gravel/light trails. Leaning heavily toward centerlock right now.
I've been using SMRT 99 140mm & 160mm rotors
Lightish
I've had no issues
Less than $50US. I don't know if that counts as budget?
Building Spec Allez
Sold
Sold -
Sold
Sold -
I use Sram Centerline centerlock rotors ( 140 rear, 160 front ) - silent, efficient, hard to bend. Works for me. Next will be Campagnolo. Nothing wrong with Sram- but if brakes are made by Magura, rotors are thicker than anything on the market / read stiffer with better heat dispersion /
Mark Twain
I can be wrong, and have plenty of examples for that
Mark Twain
TRP’s are pretty decent at absorbing heat, dead straight, has had round edges from start and pretty lightweight.erickr wrote: ↑Mon Jan 01, 2018 2:51 pmI'm looking for some suggestions on disc brake rotors. Mostly looking for good price to value as this is a budget build using spare parts and and lightly used ebay deals. These will be used with Shimano ST-RS685/RS805 on a Carbonda 505 that will be used for commuting/gravel/light trails. Leaning heavily toward centerlock right now.
And they are significantly cheaper than shimano’s xt/ultegra offerings (and lighter)
mvh. Morten Reippuert Knudsen @Merlin Works CR, Chorus 15, Reynolds 46/66
